Front spacers
07-03-2017, 07:42 PM | #1 |
Rep 206
Front spacers
I'm looking for some 15mm spacers to go on the front of the E90. It has ISPIRI ISR10 8.5j ET35 wheels on the front with 235 rubber. Will 15mm be ok and if so, where should I get the from, what brand or are they all the same?
Thanks Ad. |
07-04-2017, 02:35 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
I got my spacers here:
https://www.performancealloys.com/ I'd recommend Eibach or H&R. You can get cheapo spacers on eBay, but IMHO this is a safety-critical part and I wouldn't compromise on quality. Whatever you do, don't go for anything other than hubcentric. As to what size you need, the best advice is to measure your own set-up, as what you can fit will vary with wheel and tyre types. There's a how-to guide here:
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-04-2017, 10:30 AM | #3 |
Rep 192
Hub buddies and/or Bimmec are great spacers! Have them for just under a year with no problems whatsoever. Well priced too I think they're like £30-£40.
Absolutely don't go for the cheapest there is, but also there's probably no need to go for £100 spacers for road driving. |
07-17-2017, 05:15 PM | #4 |
Rep 169
What size ispiri you got on the rears 10j? Any rubbing issues and are you lowered? Looking at them wheels for myself and just wanna avoid any problems
11-19-2017, 10:48 AM | #5 |
Rep 206
Depends if you've got an LCI or pre-LCI. I have 10J ET33's on my LCI and I got scraping on undulations, just had the arches rolled to eliminate this.
