07-08-2017, 12:39 AM | #1 |
Rep 312
Tire pressures for track day
So I'm looking forward to my first track day and was wondering if or how I ought to alter my stock Pirelli summer tire pressures for best performance.
Thanks to all for sharing their wisdom. |
07-08-2017, 01:29 AM | #2 |
Rep 771
Believe that if you open the drivers side door it says the right tire pressure for below 100 mph or above. I think it's the yellow sticker.
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension. Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe. |
07-08-2017, 01:33 AM | #3 |
Rep 6,003
07-08-2017, 02:28 AM | #4 | |
Rep 312
I was particularly wondering if cornering would be improved by going _down_ in pressure a few psi. |
07-08-2017, 10:54 PM | #5 |
Rep 456
Good to see you heading out for a track event. I was at PR yesterday with the ACNW group and ran my Bridgestones in the low 30s. If you're running with the BMW club next week, I would ask Jeff Butler who puts on/helps out with the event, his recommendation.
07-08-2017, 11:01 PM | #6 | |
Rep 6,003
07-09-2017, 01:18 AM | #7 |
Rep 766
Dont worry about it too much. Set them at the OEM pressures and then listen to your instructor. As the day progresses you'll be letting air out as the tires heat up and pressure increases. On your first track day you'll be concerned more with learning the line and learning how to brake than extracting much performance out of the car. If the tires are especially stiff or soft your instructor may advise you to adjust the PSI's accordingly if the sidewalls are rolling on you, but overall just set em to OEM and watch/learn how they behave as they get heat into em.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
Polo088161610.00 defrakt6191.00 |
07-09-2017, 02:44 AM | #8 | |
Rep 312
07-10-2017, 07:37 PM | #9 | |
e90noob
1588
Rep 1,862
with my original 225/45/18 and 255/40/18 MPSS tires, i typically dropped my PSI from 34 cold to about 30 cold PSI for my track days they would usually heat up to 37-38 PSI during the actual runs i haven't done a track day with my MP4S 245/40/18 square setup yet but i just did 2 autocross days i started off at 36 PSI all around and eventually let out the air to be 38 PSI when hot when the tires cooled, i was at 30.5-31 PSI
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
danieliskander45.50 bjcarls458.50 |
07-14-2017, 12:22 PM | #10 | ||
Rep 312
07-17-2017, 02:21 PM | #11 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Figuring out good starting pressures depends on many variables - first and foremost, your specific tires and sizes - but a typical hot tire pressure target is 38psi. So if you're running in hot summer weather, then starting at around 30-32 psi "cold" is a safe bet.
10-03-2017, 02:39 PM | #12 | |
Rep 1,127
There are little triangles along the sidewall. The tire shoulder should roll enough to just clip the tops of the triangles. If the wear is well above the triangle, decrease presure to let the sidewalls roll more, well below increase pressure to stiffen up. |
lpaulodt214.50 |
