07-20-2017, 01:41 AM | #1 |
Rep 82
M Performance side skirts fitting
Hi.
I have a set of M Performance side skirts ready to fit. I don't have any screws/bolts/clips with them. Does anyone know which screws/bolts/clips are required? Many thanks Chris |
07-20-2017, 06:04 AM | #2 | |
Rep 3,035
To clarify are you referring to side skirts aka rocker panels or side skirt "extensions".
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
07-20-2017, 01:57 PM | #3 |
A family of bimmers
2757
Rep 7,743
the actual side skirts or the extensions? if you are swapping your stock side skirts with msport side skirts i would assume the existing fasteners would be used. If you are referring to the mperformance extensions, you'll need 17 1/4" push fasteners and 11 screws (oval-headed screw, 4.2x14mm part number 7 133 533) per side. They should have dimples in the extensions for where to drill the 1/4" (for the push fasteners) and 3mm holes (for the screws)
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-22-2017, 12:52 PM | #4 | |
Rep 82
