07-26-2017, 09:55 PM | #1 |
Rep 41
Drives: F87 M2 Long Beach Blue
Windshield washer pump fail due to "wrong fluid"?
My washer pumps failed and the dealer says it's because I used orange Rainx washer fluid. I suspect the fluid drained because the seal/pump failed before I added rainx since I apparently emptied the washer fluid reservoir without using it. Has anyone else been told they can only use blue washer fluid?
07-26-2017, 10:29 PM | #2 | |
Rep 4,254
///M Power
07-26-2017, 10:30 PM | #3 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Audi pulls this same kind of BS - last time I brought my TT in I asked them to adjust the washer nozzle, since it was aimed kinda high when I got it. They explicitly noted on the repair order that there was orange fluid in the tank. Not sure how different color fluid would cause the nozzle to be aimed too high and spray over the car...
(this forum needs a more sarcastic / irritated rolleyes smiley... doesn't cut it with that stupid smile)
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
07-27-2017, 12:52 AM | #4 | |
Rep 7,298
M3 Adjuster7905.50 |
07-27-2017, 09:41 AM | #6 |
Rep 55
I've had this happen on my last car. A VW. Thought I was being clever for buying the orange stuff but that ended up ruining the sensor and the whole unit had to be replaced.
M3 Adjuster7905.50 ried791.50 |
07-27-2017, 12:05 PM | #7 |
Doc Brown
1176
Rep 2,174
Yeah, BMW sells a specific concentrated windshield washer fluid that you mix with water. You are not even supposed to use any generic blue fluid, theirs only. According to them.
07-27-2017, 12:59 PM | #9 | |
this is the way
18149
Rep 8,527
Yup |
07-27-2017, 02:07 PM | #11 |
Rep 5,874
The RainX stuff leaves a film on wipers and so I assume it would do the same to a reservoir or other parts. I wouldn't use the stuff anymore. Now that being said, your dealer sounds like they're pulling some BS though.
07-27-2017, 02:10 PM | #12 |
Rep 55
07-27-2017, 03:27 PM | #13 |
Rep 1,086
Another "problem" is that Rain-X on the area of the windshield over the rain sensor and video camera for the nannies makes the glass too slick and messes with the calibration of the electronics. I guess it's back to the good old days of applying Rain-X by hand - except on the glass over the sensors. Has anyone contacted Rain-X about this?
The new bottle of Prestone green summer windshield washer fluid I have in the garage says it's safe for all rain-sensing systems, but there's no list of ingredients. |
07-27-2017, 03:37 PM | #14 | |
bad ***** poster _
278
Rep 270
07-27-2017, 04:24 PM | #16 |
Rep 2,200
Its funny but I don't even remember using the washer fluid. Car is kept clean most of the time so I try not to dirty it up with the fluid lol
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
07-27-2017, 06:21 PM | #17 | |
I INDIC8
612
Rep 1,286
Same goes for the camera - it's behind the glass. Why would it care if the glass is coated? Instead of the rain sheeting up in front of it, it will bead up and blow off from the wind. This all seems like
07-27-2017, 11:37 PM | #18 | |
Rep 1,086
ZPrime611.50 M3 Adjuster7905.50 |
07-28-2017, 12:30 AM | #19 | |
I INDIC8
612
Rep 1,286
From what I understand, they basically look at "how much cold liquid is hitting this small sensor area per second / millisecond" and from that extrapolate how often the wipers should run, with the assumption that rain is roughly uniform random distribution / density. The only thing that you are changing by adding a hydrophobic coating is the way the water moves over that sensor - instead of sheeting and running up it slowly, it beads and skitters off. (Coefficient of friction isn't really changed by these coatings, they actually mess around with the surface and make the water bead instead of spreading out.) If what the engineer told you was accurate, you should be able to coat the whole window except the sensor and have the wipers perform exactly as they did before. However, the water is not moving across the rest of the window the same way... after coated it tends to fly up, so if anything I'd think that leaving the sensor uncoated should cause the wipers to run more often than normal (due to the beads from lower on the window skating up to the sensor and then pooling up when they hit the uncoated section). This is all conjecture on my part as I'm not an automotive engineer specializing in wiper systems though. I know someone who works for Delphi, I'm going to ask him if he can run this past a coworker because I really want a definitive answer on this. If covering all of the glass except the sensor is "best" then I'd love to know that... if they think that coatings are completely bad regardless, I want to know that too... but that will suck because Aquapel is really nice in the winter (it helps keep ice from sticking to glass as easily too).
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 07-28-2017 at 04:11 PM.. |
07-28-2017, 01:22 PM | #21 |
Rep 58
Looking at how they work, I read on an article:
"The sensor projects infrared light into the windshield at a 45-degree angle. If the glass is dry, most of this light is reflected back into the sensor by the front of the windshield. If water droplets are on the glass, they reflect the light in different directions -- the wetter the glass, the less light makes it back into the sensor." http://auto.howstuffworks.com/wiper4.htm There are 3 things that could happen here. If there is a coating that makes it so less light is reflected back at the sensor and is beyond the sensitivity threshold, it could trigger more frequent wiping. The other is that the coating is thin enough to not trigger, but when water hits it and beads and slides off the sensor area, it could trigger less wiping which may be the desired outcome here as that is the reason for rainx, right? You only want the auto wipers to come on when the water on the windshield is otherwise obstructing you view. If the coating is helping with that, then you would theoretically want the wipers to wipe less often. |
07-30-2017, 08:21 AM | #22 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
Tags |
washer fluid, washer pump |
