M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Sat Nav - Updating to 2017-2 Map Data (Europe)
      08-05-2017, 11:27 AM   #1
mjsaville
United Kingdom
101
Drives: M2 LLB - Arrived 4th Mar 2017
Post Sat Nav - Updating to 2017-2 Map Data (Europe)
Hi All,
I'm just making people aware there is updated European map data available for our Sat Nav's, albeit you need to locate it and download it from the Interweb.
My car came with Sat Nav map data NBT EVO version 2017-1 from new, although its set to auto update the car has never auto updated automatically.
Today, I downloaded BMW Road Map EUROPE EVO 2017-2 and manually installed it without issue (no security codes were required for the update). On the Connected Drive Store updates are included until 2020.
The download is around 30GB, which I copied to a newly formatted (exFAT) 64GB USB Data Traveller stick, plugged it into the centre console and went into the Sat Nav settings when you select the current version it prompts to say there is a newer version available on USB media, and asks you if you wish to update it. When you click the acknowledge, it then starts to copy the data (you may need to power off / power on the engine before the data copy starts):
Then, Once completed:
*** Please note: I did this with the engine running, taking the car for a drive once the update started until the update completed. Timescales for the update maybe 20 - 30mins ?? ***
Now my Sat-Nav Map Data shows: Road Map EUROPE 2017-2:
Rgds
MJ
PiK61.00
DoZZa81.50
      08-20-2017, 01:22 PM   #2
EliseNE
EliseNE's Avatar
United Kingdom
Drives: Elise, M2
Having trouble in that it seems that the new version is not being found on the USB stick.
I assumed that you unpacked the download on your Mac/PC. After doing that I see a folder named "Road_Map_EUROPE_EVO_2017-3". Did you just leave everything in this folder and copy the complete folder (rather than its contents) to the USB.
For info the current Version information shows :
Road Map EUROPE EVO 2016-2
NBTevo_L17163l
then:
Automatic map update:
GB, IE 2017-3
      08-20-2017, 02:21 PM   #3
DoZZa
DoZZa's Avatar
United Kingdom
82
Drives: MY17 | M2 | DCT
I was driving from Devon to Bristol the other week and half way through the journey I get a message on the iDrive screen that there is an update available for the navigation system.
I selected to continue with the update, as it warns that the navigation system needs to be restarted if I choose to start the update.
I'm not sure what exactly was updated, but I highly doubt that the car downloaded 30GB of data during the journey!
F87 M2 | DCT '17
E46 M3 |SMG '06
E46 M3 | SMG '03
E30 320iS | '90
E28 M535i | '84
      08-20-2017, 05:57 PM   #4
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
United Kingdom
484
Drives: F87 M2<E92 M3<E46 M3
Mine updated OTA today. Easy.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      08-21-2017, 03:14 PM   #5
mjsaville
United Kingdom
101
Smile
NBTevo_L17163l
then:
GB, IE 2017-3
I downloaded the zip on Windows 7 laptop, extracted the files onto newly formatted 64GB USB Stick , left the structure as is and the file structure looks like:
and within the folder named 1 -
Hope this is helps.
MJ
      08-21-2017, 03:27 PM   #6
mjsaville
United Kingdom
101
Yep, I would agree it is unlikely to download 30GB as you say. That said, the Sat-Nav as not yet asked me to update it. (and I'm impatient - hence the manual update).
MJ
      08-22-2017, 03:07 PM   #7
PiK
PiK's Avatar
Poland
61
Drives: M2 6MT
2017-3 available.
Updated 10 minutes ago using USB stick.
I was getting unzip0077 error when trying to extract maps onto a USB memory using BMW Download Manager although using FAT32 file system. Had to manually extract the zip file located in the user home directory: %userprofile%\bmw-dlm\dl
The file/directory tree on the USB stick:
Don't panic when iDrive shuts down after idle timeout during the update. The process won't be interrupted, so just turn the iDrive on.
m2
