BMW 5-Series (G30) Forum Cosmetic Modifications Gloss black grill DIY?
      08-11-2017, 10:10 PM   #1
soco352
soco352's Avatar
Drives: F87 M2 (On Order)
I searched but didn't see any DIYs posted. Has anyone installed the black gloss grills themselves? How easy was it to do?
      08-12-2017, 08:54 AM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Very easy to do.
Open up the hood. You will see slots to undo the locking tabs from the top of the kidney grill.
Use flat screw driver, press them in one by one while pulling the kidney grill out.
You don't need a lot of pressure or a pulling hard on the grill.
It comes off very easy.
Good luck.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
soco35277.50
eclipxe170.50
UKF302524.00
      08-14-2017, 03:22 PM   #3
Bandiano
Bandiano's Avatar
United Kingdom
84
Drives: F11 530d Msport Touring
Originally Posted by r33_RGSport View Post
Very easy to do.
Good luck.
Agree really easy, even I managed it in 3 minutes.....
Looks great in my opinion, small cost for big difference.
BMW F11 535d Msport touring
Jaguar XKR100 Convertible
Mini Electric
      12-28-2017, 01:26 PM   #4
UKF30
UKF30's Avatar
United Kingdom
2524
Drives: BMW G30 LCI Black Saphire
Very easy to do.
Good luck.
Thanks mate I will be trying to do it tomorrow
      01-07-2018, 07:01 PM   #5
ksa
ksa's Avatar
Drives: Aston Martin Vantage & others
Did anyone try this? Any guide with pics preferably to give us rookies a better idea? lol
      01-07-2018, 07:08 PM   #6
soco352
soco352's Avatar
Its really easy to do. You'll see three clips up top, use a flathead screwdriver or something flat to release the clips. Then pull the grill off and put the new one on.
      01-14-2018, 09:36 AM   #7
yxc145
Drives: 2011 535i
does it work the same way for the M550? I see that the grills have flaps that open/close.
      01-14-2018, 02:33 PM   #8
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
M550 has the same grilles as the rest.
instructions for removal are as above. You will see that the opening/closing flaps are not part of the cosmetic grille that is removed; the flaps are on the car and undisturbed by grille removal.
      01-14-2018, 02:42 PM   #9
yxc145
Drives: 2011 535i
thank you for the info.
      01-29-2018, 01:06 PM   #10
UKF30
UKF30's Avatar
United Kingdom
2524
Very easy to do.
Good luck.
I just changed my grills and man it literally took less than a minute pulled straight off , way easier than F10 grills
I have also changed side fender trims , did exactly as you said and less than a minute both off , will uploads pics soon
Thanks a lot mate
r33_RGSport12971.00
      01-30-2018, 03:27 PM   #11
UKF30
UKF30's Avatar
United Kingdom
2524
Here it is all changed
r33_RGSport
I painted my chrome grills rather than buying new ones , here is what I did
I prepped with scotch bright
2 x coats of plastic primer
2 x Gloss black coats
2 x clear lacquer coats
      02-02-2018, 09:10 PM   #12
ksa
ksa's Avatar
Finally got my grille...will try to tackle this tomorrow. Hopefully it's as easy as what everyone is saying. Wasn't all that straightforward on my F80 M3 even with an actual guide. And I don't even have a guide for this one. lol
      06-18-2018, 03:50 AM   #13
The Donald
Thailand
10
Drives: 520d G30
is there a way to manually open/close the shutter grills?
since installing the double slated version i would like to test if it gets stuck or not...
or do i have to patiently wait till the engine heats up for it to automatically opens and then wait for it to cool down for it to shut.
5post
