E92 330i water pump
08-23-2017, 01:01 PM | #1 |
Rep 94
E92 330i water pump
So I was heading to work this morning, about 5 miles into my journey I see an error on the iDrive screen: Engine temperature too high.. drive moderately to allow the engine to cool down. The car lost power, couldn't go above 25 -30mph.
I pulled over, switched off the engine and let the car cool down. Quick Google search tells me the water pump has gone. 20mins later start the car back up and all seems OK, a mile later, same error and same issue. Pulled over and arranged my car to be towed straight to an independent garage. Left it with them, a while later they called and confirmed it was the water pump. They will be replacing that, the housing, thermostat and I think a sensor. Will be costing me just shy of £800 all in... that sound OK to you guys? Car will be ready tomorrow. Last edited by German_Whip; 08-23-2017 at 01:16 PM.. |
08-25-2017, 04:02 AM | #2 |
Rep 512
The water pump is a common failure, mine failed a few months ago, I changed it myself and it wasn't a nice job. The pump itself was about £250. I got quoted in the region of £800 by a specialist so your quoted price seems ok.
08-25-2017, 05:07 PM | #4 |
Rep 94
Thank you both, it is not something I could change myself, but as your quotes are in the same ball park, that has put my mind to rest.
Starter motor went last year, water pump this year, its a 2007 plate, 125k on the clock, serviced every year. Anything else that is common or I should expect? |
08-26-2017, 07:08 AM | #5 |
Rep 3,200
Drives: E92 325i MSport Coupe
If it's an N52 I'd also keep my eye on:
I assume you're aware of Mike Miller's old school BMW maintenance programme? You might get a few other ideas from that.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-27-2017, 03:11 AM | #7 |
Rep 84
About standard price. You can do it yourself it's just a bit awkward and most of the work needs doing from underneath, the worst bit is antifreeze in your mouth lol.
08-28-2017, 05:43 PM | #8 |
Rep 101
The parts cost around £250 from eBay. Labour should be no more than £150.
E90 330i SE Manual / Bilstein B12 Pro / M3 Control Arms / Performance Exhaust / CDV Delete
