Looking for a damaged 2009 and up head
08-31-2017, 08:55 AM | #1 |
Rep 215
The title says it all. I'm looking for a used N52 head from the 2009 and up car. I don't mind if it has cam ledge issues as I am going to machine out the valve-tronic. Please forgive the section placement. I know someone in here is likely to have what I'm looking to find. I would prefer someone from around Ohio, as the part will be getting shopped to Cleveland. Please pm me if you have something. Thanks.
08-31-2017, 10:27 AM | #4 |
Master Wagon Builder
413
Rep 881
I have a 2011 N52 head with 50k miles. No lifter tick, or any other issues.
It was removed due to lower engine block damage. Located in Metro Detroit, can meet up closer to Toledo, Ohio if needed. Shipping obviously is no issue either. |
Hobbs6438.00 |
08-31-2017, 10:40 AM | #5 |
Rep 7,215
would be a shame to hack up such a clean/low miles head though. How much you want for it? I'm actually thinking on my N52 build, I'm not going to use the head that came with the engine anyway - other than maybe for experimentation..
08-31-2017, 11:40 AM | #8 |
Rep 7,215
lol
if you're building a race engine, just make solid shims.. they bleed out at high RPM anyway. I was looking at the lifters and it would be relatively simple to do. you could probably even convert the stock ones to be "solid" - the only need an oil hole to lubricate the end of the rocker. |
