Brake sensor question
09-16-2017, 05:45 PM | #1 |
Rep 49
I had the red car lift sign going on and off for a while ... and eventually turned on permanently.
I changed brake pads and rotors not too long ago, so I suspect one of break sensors is broken. The question is, if I am right about the observation, is there a way to find out which brake sensor(front driver or rear passenger) is busted without taking off the wheel? Thank you |
09-17-2017, 03:53 AM | #2 |
Rep 1,815
You should have changed out the sensors when the brakes were done. The sensors trip and must be replaced or bypassed ( create a loop harness).
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
09-17-2017, 09:54 AM | #3 |
Fuck it dude, let's go bowling.
888
Rep 2,479
Where is BrakesNotBreaks when you need him?
Always best to replace sensors when doing the brake job. Take the sensors out and inspect them. See: http://www.e90post.com/forums/showthread.php?t=1272593 TLDR: go to the last post.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
