Too Many Codes !
09-16-2017, 09:55 PM | #1 |
Rep 233
Too Many Codes !
ok so my 09 335i has a TON of codes even after doing brand new injectors and plugs coded perfectly. also, all coils are seated properly.
if i know what the problem is, i'll just fix it. problem is, i can't diagnose very well. Codes from my cobb ap are: P0420 - CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD BANK 1 P0430 - CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD BANK 2 P0305 - CYL. 5 MISFIRE P29F4 - CATALYTIC CONVERSION P29F5 - CATALYTIC CONVERSION 2 P29D1 - CYL. 5 MISFIRE P29CD - CYL. 1 MISFIRE P29CC - MISFIRE MORE CYL. P29D2 - CYL. 6 MISFIRE P29CE - CYL. 2 MISFIRE P29D9 - MISIFRE W/ LOW FUEL LEVEL P29D0 - CYL. 4 MISFIRE These are the codes that had no description: H2DED H2FCA H2FDA H29CF H29D2 H29CE H29CC H29DB PLEASE HELP ! |
09-17-2017, 06:04 PM | #6 |
ahat
1036
Rep 2,592
so this is during normal driving?? WFO? idle?
what? And you might want to try the AA board - http://www.e90post.com/forums/forumdisplay.php?f=58 Dont worry about the cat ones now. They are missfire related. Check all grounds to injectors.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
09-18-2017, 12:01 PM | #7 | |
Rep 342
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
335e92tx1036.00 |
09-18-2017, 08:50 PM | #9 |
Rep 1,484
i would check your plugs and coils again. try swapping the coil in cylinder 3 and see if it gets rid of one of the miss fires to make sure its not bad coils. Make sure none of the connections are loose.
09-19-2017, 07:54 PM | #10 |
Rep 233
the car has never been walnut blasted and i'm at 129k miles now so i'm pretty sure i need that BAD
i will clear all the codes and swap out coil number 3 with coil number 5 and see what happens and report back i haven't been driving the car hard at all b/c of these issues |
11-03-2017, 10:58 PM | #11 |
Rep 233
ok so here's the latest - found out i have a bad coil
i replaced it and cleared the codes and the SES light just came on again but now there's only these 4 codes: P0420 Catalyst system efficiency below threshold bank 1 P0430 Catalyst system efficiency below threshold bank 2 P29F4 Catalytic conversion P29F5 Catalytic conversion 2 So i'm thinking that i need cats - am i correct ? if so which cats are bad as there are four of them...options? i DO NOT want to deal with the problems of passing emissions with catless downpipes etc. but at the same time i AM NOT willing to shell out 4k for 4 brand new genuine bmw cats ideas ? |
11-04-2017, 08:49 AM | #12 | |
Rep 2,203
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
11-04-2017, 09:25 AM | #13 | |
Rep 49
11-06-2017, 10:02 PM | #14 | |
Rep 233
it "could" but i do NOT want to change the o2 sensors and still find out that it's the cats - i need a definitive way to determine this |
11-06-2017, 10:43 PM | #15 |
Rep 459
I think you might already have catless downpipes. All four of your current codes point towards that.
Pop open your hood and look down the left side of the engine, by the turbos. Just below the rear turbo wastegate actuator, you will see the downpipe. Is it big and bronze colored with a clearly visible BMW logo? You should be able to see it pretty easily just by opening the hood, though you might want a flashlight. |
11-06-2017, 11:33 PM | #16 |
Rep 2,015
11-07-2017, 09:00 AM | #17 | |
Rep 564
If that's the case then I would suspect your O2 sensors are the problem. I know you said you need a definitive way to test this without replacing the O2 sensors first but that's the only way. However, there are 4 O2 sensors on these cars and you might only need to replace two. In order to figure that out you need to get yourself a better scan tool. If you can hook it up to MHD (free for reading codes) you can get the actual BMW codes instead of the OBDII codes. They don't help as much on these cars. I had 29E0 and 2A2B when my upstream o2 sensors needed to be replaced. Swapped them out and my codes were gone. Super easy fix but you have to be willing to try to fix it first otherwise you'll never get it done. |
11-10-2017, 10:25 PM | #19 | |||
Rep 233
the car is bone stock basically i'm thinking its the cats b/c when i try to boost on power i don't get much - i think it's getting worse - feels bogged down well aren't you super helpful ! lol i am trying to avoid paying a diag fee here kevin |
11-18-2022, 07:34 PM | #20 |
Rep 1
08 bmw328xi idrive, many codes.
I had just purchased this car its completely stock with 120k on it. From the start i had a tpm sensor light on, after driving like 2k miles i got a p027 code, then i got SES light. I did an oil change and tried to reset the oil service but it wouldnt work. After i did the oil change the car was fine. I then did the knock sensors and then got all these codes!!! The car starts and then immediately stalls. I also have a tremendous amount of lights of the dash and i cant use the odometer button (holding for 10 seconds) it will not work, i also can not press the BC button to scroll through service lights on dash! Tbh i am lost....
Codes recieved after replacing knock sensors A6CF 93DO 9408 940A 93D1 5E3A D359 5DD0 D36D 5F3A 5EBA 2E7C |
