E90 330D - Rocker Cover Removal?
09-30-2017, 03:36 AM | #1 |
Rep 828
Hi All,
I was wondering if there where any guides on removing the rocker cover on the M57n2 Engine? I've took the Intake Manifold off before so I'm okay up until that point. Also, would a rocker cover gasket set such as "Febi" (fleabay) or "Elring" (eurocarparts) be okay? I haven't inquired at the stealership yet, but given the prices they gave me for the Intake Manifold gaskets I reckon there price will be extortionate. with the Rocker Cover removed, I could check for play in the upper timing chain but is there anything else I can look for while it's off? Is it possible to check if the valve stem seals are passing oil? or is it possible to check the Hydraulic Lifters which cause the famous ticking sound? Cheers. |
02-11-2018, 05:00 AM | #4 | |
Rep 828
http://tis.bmwcats.com/doc1108462/ |
02-20-2018, 01:01 PM | #6 |
Rep 828
