Part compatibility in realOEM
10-04-2017, 07:26 AM | #1 |
Rep 45
Hey all,
Still in the learning phase of BMW ownership and I have a question regarding the reliability of realOEM's compatibility listings. In my experience with other brands of automobiles and mortorcycles part numbers aren't always the same between models even if they are in fact the same part, but how about with realOEM? Can I safely assume that if a particular part shows compatibility for my e91 only that's really the only vehicle this part is compatible for? Just to be specific, I'm looking for a replacement tailgate light and was hoping the sedan's taillights would be compatible, realOEM says they aren't... |
10-04-2017, 09:33 AM | #2 |
Rep 7,215
If the part numbers are different, then they are different, unfortunately. BMW doesn't tend to change part numbers for the same part. The database RealOEM uses is the EKT, the factory MySQL database that pretty much lists every single part and model BMW has ever produced.
10-04-2017, 10:08 AM | #3 | |
Rep 45
10-04-2017, 12:44 PM | #4 |
Rep 7,215
Yeah I mean if you look for certain parts they were literally used for 20+ years without changing much, same part number. if the part number changes due to a redesign etc. then the old one is discontinued and superseded by a new number but the cross references remain the same..
10-04-2017, 01:27 PM | #5 | |
Rep 45
10-04-2017, 07:16 PM | #6 |
Rep 2,203
To what you are specifically asking for. That is either a fit or will not fit. you may have to do trial and error for that.
I remember doing the CA retrofit earlier on and researched door handles. Precisely realoem showed same part # that will fit the E90, E91 and E92, and E7x X6 Chassis Didn't state that it fits E93. However, the member I got them from on here had an E93 and showed that the handle fits his E91 just the same.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
10-04-2017, 07:23 PM | #7 | |
Rep 45
EDIT: Just thinking out load here, although realOEM didn't show the e93 part as compatible, do you know if that 93 part was the same part #? The e91 taillight and the e90 taillight are different part numbers and I guess the crux of my question is whether or not parts, with differing part numbers, can fit applications they're not "supposed" to, like my two taillights in question? |
10-04-2017, 07:38 PM | #8 | |
Rep 2,203
10-04-2017, 08:32 PM | #9 | |
Rep 45
Ok, understood, I appreciate the knowledge. |
10-10-2017, 04:12 PM | #10 |
New Lifetime Replacement Policy
821
Rep 11,738
realoem is a BMW ETK dump, it's the closest publicly available thing to the dealer parts database. Compatibility is pretty cut and dry, but pay attention to vin/build date splits. They can sometimes get confusing if you're a build on the split car, I'm always here to help in those situations, I have dealer portal access which can clear up some of those fun splits.
As for the tail lights; coupe, sedan, touring, vert all different shapes. |
10-12-2017, 09:33 PM | #11 |
Rep 45
10-16-2017, 10:50 AM | #12 | |
821
Rep 11,738
-James |
