Strange TPMS issue
10-06-2017, 06:57 AM | #1 |
Rep 23
Strange TPMS issue
Hi,
My 2010 e90 has TPMS. I recently installed my spare tire to fix my rear rim and inflated it to the correct pressure. The spare tire does not have a sensor. I was expecting an error from the TPMS because there was one sensor missing but it didn't happen. Also in the Idrive screen, the 4 tires are in green color indicating the pressure is correct in all 4 wheels. Any clue why the system did not complain about the missing sensor? Regards |
10-06-2017, 08:58 AM | #2 |
Apprentice
373
Rep 801
1 of 3 things: 1. Your spare has TPMS. 2. You stuck your old tire in the trunk and it's still reading it's pressure. 3. Your TPMS is faulty.
Just guessing here... |
10-06-2017, 02:29 PM | #4 | |
Rep 1,416
However that hypothesis makes no sense since our cars come with run flats and the TPMS programmers would not have thought that far ahead.
10-08-2017, 09:08 AM | #5 |
Rep 342
I would guess that your car is setup with FTM-'Flat Tire Monitor' and not TPMS-'Tire Pressure Monitor System'. What does it say in iDrive?
TPMS uses sensors in the tires, to monitor actual pressure. FTM uses the DSC to monitor the roundness of the tire. They both are designed to notify the driver when a tire goes flat. Even if the car came with TPMS, it's possible to code it to use FTM instead. That way you never need to worry about the sensors when you change tires.
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
