HELP! Oil Filter O-Ring Blown-Out
10-19-2017, 03:11 PM | #1 |
Rep 503
Hey guys! I need some help figuring what caused this issue!
I was driving home when I stopped at a red light and noticed some smoke coming from under the hood. I was 2 minutes from home, so I decided to limp it back keeping close watch on my temperature and oil levels. When I got home and popped the trunk, there was oil that seems to have come from the oil filter housing spread across the engine (which caused the smoke). The part that confuses me is, what would cause that gasket to be blown out? What would cause that much pressure? Has this happened to anyone? I am currently keeping close watch to monitor if there are any other areas/gaskets leaking, but as far as I can see, the oil all came from the oil filter housing. Thank you in advance!
// 328i E92 // N52 // Muffler Delete // K&N Drop In // Charcoal Delete // RGBW LED Halos Last edited by dspence44; 10-19-2017 at 10:00 PM.. |
10-19-2017, 04:38 PM | #2 |
Crazy Frog
543
Rep 1,212
goddamn...you are f**ked. The oil filter housing gasket is a common problem on these cars, but they don't just "blow up" or burst open like that. The leak starts small and spreads. Most people who pop the hood at least once a month will notice it for sure and get it repaired at a shop or DIY it.
-Either you almost never pop the hood, or you saw it and chose to ignore the problem What was originally a $10 DIY or $200 indy repair is now probably a $1,000+ repair. |
10-19-2017, 04:54 PM | #3 |
VAG Survivor
40
Rep 150
Why would It be a 1k repair ?! Why is he f**ed? Stop scaring ppl lol.
OP: Clean the engine bay, replace the gasket(s) for the oil filter housing and the oil cooler if present and be done with it. Maybe also replace the serpentine belt as it is known to slip and get chewed up by the engine if oil drips on it so better change it.
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
10-19-2017, 04:55 PM | #4 | |
Rep 1,425
http://www.e90post.com/forums/showthread.php?t=476419 |
10-19-2017, 10:01 PM | #5 | |
Rep 503
// 328i E92 // N52 // Muffler Delete // K&N Drop In // Charcoal Delete // RGBW LED Halos |
10-19-2017, 10:51 PM | #6 |
Rep 1,425
10-20-2017, 10:47 AM | #7 |
Rep 952
If you are lucky, the cap over the filter was not tight. As it got looser, only the o-ring was holding in the oil pressure. Eventually the cap got looser, the o-ring gave out. If this was the case, you don't have any serious issue in your engine, just make sure the cap is tight (not too tight). The cap on mine is marked with a green arrow that lines up to a mark on the housing to show that the cap is tightened.
Now for another possibility that is far worse: You have some sort of over-pressure or blockage issue that caused higher than normal pressure in the cap. I would say this is very un-likely and a loose cap is more likely. If a blockage occurred part of the car would not be getting oil pressure and in short order bearings would begin to fail. Again highly un-likely. My advice: clean up. Change the oil, filter, o-rings, and maybe even get a new cap. Also replace the serp belt. Then see how things run.
bone stock
10-20-2017, 11:06 AM | #8 | |
Rep 99
I experienced something similar. Either the O-Ring was defective or more than lucky torqued down too tight. Or not placed on the Oil Filter properly lined up.
M-Tech Aero Kit with Custom Quad Diffuser
ACS Rear Spoiler, ACS Roof Spoiler Quad Magnaflow Exhaust,AFE Intake, Sprint Booster |
10-20-2017, 11:15 AM | #9 |
Rep 1,023
FYI, there is a torque spec for that cap. It's the same as the drain plug, and you can get adapters online that let you put a socket on it.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-20-2017, 11:57 AM | #10 |
Life is better with burnouts
99
Rep 611
Make sure whoever did the last oil change may have put the oring in the wrong groove(ask me how I know). Make sure the oring is in the right groove or it will leak.
10-20-2017, 01:05 PM | #11 | |
Rep 2,793
GL OP |
10-20-2017, 02:31 PM | #12 |
Crazy Frog
543
Rep 1,212
OP, whatever the problem is (hopefully just an O-ring or filter cap) get it fixed ASAP....This job looks easy enough to just DIY it. After you fix it up, please please please make sure there is NO oil at all on the belts. NOT EVEN A SINGLE DROP...if the belt slips off and shreds, your engine is most likely toast. Better start searching on Craigslist for a used N52 engine.
10-21-2017, 03:35 AM | #13 | |
Rep 2,109
Even if it is put in the correct groove, if the oil ring is not lubricated with some oil, it can climb up during screwing in the cap. When you tighten the oil filter cap you shouldn't see any of the o-ring, it should be staying all inside. |
10-21-2017, 08:08 AM | #14 |
Rep 293
Drives: 2008 E93 M3
I agree with the others on the wrong groove as well. I just went through this very same thing two weeks ago with my daughter's car. I just replaced the oil filter and both O-rings on the cap. All is good now. Oh yeah, and clean all the residue off the motor when you are done.
+1 on changing the serpentine belt as well |
10-21-2017, 11:16 AM | #15 | ||
Rep 2,109
10-21-2017, 01:05 PM | #16 |
Rep 1,082
If you put the oring in the wrong place like at the very top of the cap instead of the groove below the top oil will get past it
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
