E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Carly codes 2A31, 32, 35 & 36 - what does that mean?
Reply
      10-29-2017, 03:09 PM   #1
Atx328
Drives: 2011 328i sport
2013 BMW 328i  [0.00]
2011 BMW 328  [0.00]
So i recently replaced my the eccentric shaft sensor since I was experiencing a very "wild" idle. It would spike up and down from 700 to 1500 RPM and then back. I swapped out the sensor and replaced the valve cover gasket.
Everything seems to be running OK but I am still getting the following error codes when use my Carly to diagnose:
What could that mean?
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 2A31:Valvetronic, eccentric shaft sensor: guide ***
Fault-Set 1 - ( 88520 km)
Engine speed: 0.00 rpm
status Motorsteürung: 0.00 0-n
Voltage cl. 87: 11.27 V
VVT Sensor Supply Voltage: 5.00 V
Fault-Set 2 - ( 88520 km)
Voltage cl. 87: 11.37 V
Fault-Set 3 - ( 88528 km)
Voltage cl. 87: 11.88 V
*** 2A32:Valvetronic, eccentric shaft sensor: Reference ***
speed: 0.00 km/h
speed: 0.00 km/h
speed: 0.00 km/h
*** 2A34:Valvetronic, eccentric shaft sensor: Reference ***
Engine speed: 96.00 rpm
VVT actual angle: 179.69 deg
VVT Sensor difference: 0.00 deg
Engine speed: 1312.00 rpm
Fault-Set 3 - ( 88536 km)
*** 2A36:Valvetronic, eccentric shaft sensor: Reference ***
Engine speed: 1088.00 rpm
Engine speed: 960.00 rpm
Engine speed: 1600.00 rpm
      10-30-2017, 05:15 PM   #2
Atx328
2011 BMW 328  [0.00]
Today I got more of the same with one more added in for flavor.
I welcome any comments on the root cause, suggested fixes or troubleshooting next steps!
Found Faults:
--Engine / Motor--
Fault-Set 1 - ( 88536 km)
Engine speed: 608.00 rpm
status Motorsteürung: 2.00 0-n
Voltage cl. 87: 14.62 V
Fault-Set 2 - ( 88536 km)
Voltage cl. 87: 11.78 V
Fault-Set 3 - ( 88648 km)
speed: 0.00 km/h
speed: 0.00 km/h
speed: 0.00 km/h
Engine speed: 640.00 rpm
Engine speed: 672.00 rpm
Engine speed: 2272.00 rpm
*** 2DED:Power management, standby power control ***
Time with quiescent current 200 - 1000 mA: 0.00 min
Time with quiescent current 80-200 mA: 135.00 min
Time with quiescent current above 1000 mA: 0.00 min
Voltage cl. 87: 0.00 V
Voltage cl. 87: 7.31 V
Engine speed: 1568.00 rpm
Engine speed: 800.00 rpm
Fault-Set 3 - ( 88640 km)
Engine speed: 1952.00 rpm
      09-22-2018, 01:40 PM   #3
greenberet123
Drives: E93
Im getting the same. Did you figure this out?
      09-22-2018, 09:50 PM   #4
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Looks like the eccentric shaft
Reply
e90post
