10-29-2017, 09:01 PM | #1 |
Rep 397
OEM full leather dashboard conversion
I've seen a few OEM full leather dashboards on ebay in the last few weeks for usually around $1000-$1200. As one of my friends has the full OEM leather dash in his F80 it's something that I really enjoy and would definitely bring my car's interior more upscale.
1) Is the OEM full leather dashboard part the actual full dashboard piece that replaces my plastic full dashboard? The reason I ask is that if this is the case, I would sell my OEM plastic dashboard to recoup some of the cost. 2) This looks rather labor intensive and I don't trust myself doing this type of stuff, how many hours of labor would a reputable shop likely charge for this? FYI, this is similar to what I'm looking at: http://www.ebay.co.uk/itm/BMW-F30-F3...-/282085781522
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune *Evolution Racerwerks Competition Intercooler & Chargepipe *M Performance Big Brake Kit |
10-29-2017, 10:08 PM | #2 | |
Rep 306
It would replace your plastic dash, though those really do not move on eBay. If an airbag blows and totals dash, the car is usually totalled, so not a lot of call for replacement. I had looked at that specific opal weiss dash, but the damaged leather at the point convinced me to stay away. As your car does not have Opal Weiss interior (unless an Individual Edition which I suspect you do not have) what are you planning to do to match all the other leather and door trim? |
10-29-2017, 10:11 PM | #3 | ||
Rep 397
10-29-2017, 10:13 PM | #4 | |
Rep 306
What color is your interior now? If doing a custom dash, would suggest you use this as a base. http://f30.bimmerpost.com/forums/sho....php?t=1376288 IK6SPEED Last edited by kabrichx; 10-29-2017 at 10:31 PM.. |
IK6SPEED4495.00 |
10-29-2017, 10:20 PM | #5 | |
Rep 10,473
OP the leather dash has padding and different plastic underneath it, if you wrap your plastic dash it will look puffy and inflated on the edges and corners since ur will make it thicker/fatter. If interested send me a PM and i can give you a good deal on mine, the lower parts are already all leather, you will just need to replace the top sections with new leather, will be much cheaper then wrapping ur plastic dash with leather and it will also look much better. |
10-29-2017, 10:23 PM | #6 | ||
Rep 397
1) my car doesn't have the HUD so not sure it would line up correctly? 2) how would I potentially repair where your air bag deployed and still have my airbag system function properly?
10-29-2017, 10:24 PM | #7 | ||
Rep 397
10-29-2017, 10:29 PM | #8 |
Rep 306
10-29-2017, 10:31 PM | #9 |
Rep 397
Agree. The eBay link I provided was similar to one i saw a while back; that color contrast would look horrible with my seats.
10-29-2017, 10:36 PM | #10 | |
Rep 306
Or have a piece of the leather cut the size of the HUD hole on some backing and mount it in there instead of the screen. |
IK6SPEED4495.00 |
10-29-2017, 10:36 PM | #11 | |
Rep 10,473
your airbag attached to lower part of dash, the mounting points are all still there and intact, there is a plastic door that opens when airbag deploys, that plastic will need to be repaired and then new leather will be used on top and the seam runs along where the airbag pops out off, the shops that repair these types of things know how to repair the plastic doors so they will be safe and function properly when the airbag goes off again, for the leather they will use special breakable threads in the seam area just like the factory uses. |
10-29-2017, 10:37 PM | #12 | ||
Rep 397
11-09-2017, 01:39 PM | #14 |
Rep 397
I went back and forth in my head for days but ultimately decided to accept and live with my lowly plastic dashboard until my lease runs out in about 1.5 years. I really want the leather dash but finding one AND getting a competent installer was going to be a ton of money. Assuming I get into a G20 M340i next I'll be ordering it with a full leather dashboard assuming that is available.
