MOT Question
11-01-2017, 03:23 PM | #1 |
Rep 294
MOT Question
So this will be the first time I would need to do an MOT - in April 2018
My car has front pads due in 4800mls and MOT the will definitely be due before I reach 0mls. My question is - what kind of things do I need to keep in mind in order to prepare for MOT and what would an acceptable tolerance be on the front pads. I don't want the car to fail the MOT and I also don't want any advisories so want to make sure everything is ready before MOT. Lastly - would a BMW dealer be recommended for MOT? Car is a '09 318d with 52k mls |
11-02-2017, 04:32 AM | #3 |
Rep 94
As the pad wear sensors are not exact, you could well go down to 0 miles sooner than that, then you will get service indicator lights on the dash, even if the pads have some life left.
Probably best to change them before MOT anyway. Remember to replace the pad wear sensor with a new one, because they wear away like the pads, that's how the mileage left is calculated.
2010 E91 320i MSport
VW Corrado VR6 |
11-15-2017, 09:17 AM | #4 |
Rep 2,343
I think every year but one I've had an advisory for low tread on the rear tyres
MOT's are incredibly basic. Don't think you need to use BMW for it unless you think that impacts resale value, if you have that in mind.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
11-15-2017, 02:46 PM | #5 |
Jeff
319
Rep 1,451
I had my E90 done at the main dealers every time, that was 3 MOT's. Each time they did it for £30, it passed and they valeted it as well. Looked like a brand new car when ir came back.
Not bad for £30 - ask them to do it for that price. |
11-16-2017, 08:05 AM | #8 |
Rep 1,525
The pad life remaining milleage is only an estimate and in my experience its usually well off.
As long as you dont have the low pad warning on the kombi, you will be fine. |
11-16-2017, 02:39 PM | #9 | |
Rep 294
The low pad warning triggered about two weeks ago - so I have the Textar Discs, Pads and sensor on the way. Will be replacing them this weekend. Interestingly - the front right has started squealing constantly and looks like it might be sticking a bit - not too happy about that - but it could just be the guide pins or the area where the pads make contact with the caliper, or just the wear pattern on the discs that's making contact with the pad. Won't know for sure till this weekend. |
11-17-2017, 04:29 AM | #10 |
Rep 1,381
Only take it to the main dealer if they will match the cheapest garage you can find for MOTs.
National tyres are normally good and only £27. I wouldn't pay any more than £30 for a MOT, and having main dealer ones will do nothing to resale value.
