Instrument Cluster Issue/Question
11-02-2017, 04:32 PM | #1 |
Rep 15
I'm new to this forum and just purchased a 2007 328xi. I've never owned a BMW before so I'm still familiarizing myself with it and this forum. I greatly appreciate all the info on this site. I've researched this issue/question all over the web and in on this site but can't seem to find any info about my issue.
There is a portion of my instrument cluster that isn't working. It is the LCD area where the outside temperature and time should be displayed. I believe other service-related info is also displayed in this area when appropriate. I've seen it referred to as the Central Information Display (CID), Variable Information Display (VID), outside temperature display, etc. but I'm not sure what the official name is. I can't seem to figure out why mine isn't working at all. The lower LCD portion is working fine. I've checked fuses and, as far as I can tell, there is only one fuse for the entire cluster (58). Everything else in the cluster is working. I've also looked into whether or not this was an option that I may not have but can't seem to find any info about that either. I know my car has the external temperature sensor because I can read it through the stereo menu. I've decoded my VIN but don't see anything related to this portion of the cluster in the options list. Is this an option I don't have. I seems like I would have run across this possibility in all of my research but I haven't. My car is a 2007 328xi, no idrive. A picture of my cluster is attached. I appreciate any help offered. Last edited by rapodac; 11-02-2017 at 05:07 PM.. Reason: Attach image |
11-02-2017, 06:50 PM | #2 |
Rep 13,127
Do you have a manual if not you can get one online.
https://www.bmwsections.com/ pushing the button on BC stalk the outside stock the cycles through mpg , miles remaining on tank , avg speed and something else I cant recall. |
11-02-2017, 10:52 PM | #3 |
Rep 15
ctuna,
Thanks for the response. Yes, I have a manual and I’ve read it cover to cover multiple times. I’m familiar with the BC controls as well. My problem has to do with the display not working. I circled the area that isn’t working in the picture I attached. The manual refers to it as Area 2 on page 145. Any advice anyone has on troubleshooting would be greatly appreciated. It looks like there is only one connector for the cluster. I’ll try to locate a wiring diagram for the connector and try to isolate and test the wires for this area. I was hoping there would be any easier answer or someone with personal experience would see this and could help with a shortcut. |
11-02-2017, 11:00 PM | #4 |
Save the manuals!
6035
Rep 6,754
I doubt its the connector. More likely that the LCD board on that part is dead. It's probably cheapest to source a used cluster and have it's EEPROM wiped and code it to your car. Or you can try swapping the LCD boards, but then you ask breaking both.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-02-2017, 11:45 PM | #5 |
Rep 13,127
There is stuff on hidden menus on the Internet and it has and LED
Test in it. Google e90 Hidden Menu's. M3 guys change out the LED's on there clusters to get different colors so its not impossible. Read the following and see if you can do the LED test http://e90.wikifoundry.com/page/BC+hidden+menus May require the part of the display that isn't working to work though . Only other way I can think of to verify is use Inpa or Ista D which means buying the bimmmergeeks cable and downloading and setting those programs up . See coding subforum or bimmergeeks.net http://www.e90post.com/forums/forumdisplay.php?f=368 Last edited by ctuna; 11-03-2017 at 12:25 AM.. |
11-03-2017, 09:47 PM | #6 |
Rep 15
Thanks for the info ctuna and 6ixSpd. I’m thinking that that portion of the LCD has been covered. I found a video show how to replace the LEDs and I see how this is actually one LCD panel. Also when I look closely at the dead area it doesn’t look like an LCD screen. It sort of looks like some sort of dark (carbon?) paper or tape. You might be able to make that out in my picture. Unfortunately my car is at the shop right now getting door lock actuators replaced. When I get it back I’ll have to pull the cluster out and see what’s going on.
I’m worried now though. Why would someone cover this portion of the display? I had the car inspected before I bought it and there weren’t any major codes. It was overdue on maintenance, I think for transfer case fluids, but nothing worth covering up. Unless the previous driver just got tired of seeing the warning light and covered it instead of servicing the vehicle. Anyway, I’m just throwing darts until I get it back. |
11-04-2017, 09:31 AM | #8 | |
Rep 2,554
11-04-2017, 03:55 PM | #10 |
Rep 18,806
That section of the gauges should light up and have the outside temperature and time in as the default setting. It is an important section of the gauges since it tells you all kinds of information such a CCID codes, warning messages, low fuel, low coolant, over heating to name a few and oil level most importantly. You'll have no idea how much oil is in the engine or when to add a quart upon the +1QT notification.
What I would do is shine a bright flashlight at an angle upon it an see if the clock and temp are displayed. That section of the gauge cluster is never blank. That test would indicate the LED that back lights it is dead. |
11-05-2017, 08:42 AM | #11 | |
Rep 2,554
11-05-2017, 09:02 AM | #12 |
Rep 7,215
I think it's covered. it's one big LCD screen as you said - it doesn't make sense for half of it to be dark and the other half to be functional. Probably just some vinyl wrap or electrical tape. Hopefully it just peels off.
People do all sorts of strange 'custom' mods, so who knows.. |
11-11-2017, 09:15 AM | #13 |
Rep 15
I finally got a chance to investigate this further. Turns out the LCD was covered with electrical tape. Once uncovered, I discovered there was a red FTM warning that would stay displayed permanently. I could toggle out of it to the temp/time but after a few seconds it would go back to the FTM warning. I re-initialized the FTM system, thanks to instructions in another E90 thread, and it went away. The previous owner, seller, or dealer probably just couldn’t figure out how to clear the warning and decided to cover it. All is good now. Only warning I get is for the brakes. I plan to do those soon as they are down to 3mm in front and 5mm on back.
This site is such a rich resource. I’ll be sure to contribute if I ever can. Last edited by rapodac; 11-11-2017 at 09:16 AM.. Reason: Typo |
11-11-2017, 01:05 PM | #14 | |
Rep 18,806
11-11-2017, 07:31 PM | #15 | |
Rep 15
For now, it’s running great and I’m happy. That is, at least, until the next ‘BMW’ issue pops up. |
11-12-2017, 05:47 AM | #16 | |
Rep 18,806
Good luck with it. This Forum is great for owning an E9X chassis. You can keep these cars a long time affordably if you DIY and have the proper technical aptitude. They are tanks, even more than the E30 was IMO (I've owned both since new). Your car is lucky you found it.
