Misfiring..LPFP?
11-03-2017, 01:08 PM | #1 |
V8 Bait
207
Rep 769
Misfiring..LPFP?
Im running stage 1 aggressive MHD on my 2010 335i. Ive noticed misfires lately at high rpm in higher gears. I decided to take a log, which i posted before, but it brings up a question.
At what LPFP psi will the N54 motor start misfiring due to a weak LPFP? For example, at the top of 2nd, 3rd, and 4th (the only gears i went through during the log) my LPFP was hitting as low as 49 psi. I didn't get misfires during that run, but i have before at the top of any gear. My HPFP stayed at 1800 psi.
Broke AF
11-03-2017, 01:50 PM | #2 |
Rep 772
Drives: 2015 435i grand coupe xdrive
should be 50+ psi but mine goes lower than that and I don't have misfires so id look elsewhere
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
11-03-2017, 01:55 PM | #3 |
Rep 554
LPFP pressure won't cause misfires if the HPFP pressure is still good. Read the codes on MHD, it'll tell you which cylinder(s) are misfiring. Then check the plug(s) and/or change the coil(s). Rule those 2 out first. By the way, if your LPFP is hitting 49 and you don't plan on ever going to upgraded turbos, just replace it with a new OEM pump. Mine was hitting low 40's and now doesn't drop out of the 60s on Stage 2+.
11-03-2017, 06:21 PM | #4 |
V8 Bait
207
Rep 769
On the misfires, i was getting them only for a few days. they have since gone away, probably only momentarily. I supposedly have a stage2 fuel it pump (previous owner), but i seriously doubt it based on my log. I will in fact go with upgraded turbos in a few years. My concern is that i don't actually have that stage 2 pump, or that its dying. I want to run the E40 tune soon to hit the 1/4 mile and i don't think my LPFP can handle it. Is there a way to check what pump i have without having to open the gas tank?
Broke AF
11-04-2017, 11:10 AM | #5 |
Rep 554
There's no way to know without looking at it. It's not hard to pull up the back seat, open the cover and pull it out. (don't try it with a full tank). They make removal tools for the top cover, but I was able to carefully get it loose by using the top (rounded) end of a ratchet extension and tapping the other end with a hammer. Make sure you alternate back and forth on the clips like you would when tightening lug bolts.
