Am I the only one who finds the under car Splash shield a pain in the ass?
11-07-2017, 04:16 PM | #1 |
Rep 1,016
Anytime I want to do something I gotta remove 14 screws and I don't have power tools. Such a waste of time.. Plus my splash is broken in one spot a little bit. I think it is adding to the road noise.. I dunno tho. Next time I do work I am thinking about just not putting it back on.
11-07-2017, 04:24 PM | #2 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Just buy an impact drill and call it good. BMW engineers put it there for a reason, not just because https://www.homedepot.com/p/Milwauke...-21P/301999257 |
11-07-2017, 06:51 PM | #3 |
Rep 2,203
I actually do not mind the extra lil protection it gives from road crap these days.
Why do you need to remove it that often though?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
BeastMode335i1131.00 |
11-07-2017, 08:51 PM | #4 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Took mine off yrs ago and it's never been a issue.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
11-07-2017, 10:00 PM | #5 |
Basic Bimmer
520
Rep 935
Drives: E92 328i 6MT ///M
I believe these "splash shields" contribute to the aerodynamics of our cars. The air underneath is really important as well as the air over the auto.
I could be wrong though. Either way.. that's part of wrenching dude. I feel you though. |
11-07-2017, 10:26 PM | #6 |
Rep 73
It's not just you; it's a PITA. Plus, if I drop anything while I'm working in the engine bay it never falls through to the ground.
11-07-2017, 10:38 PM | #7 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
After some work on the front end I decided to do a quick test drive and didn't bother putting it on. The other mid section guards that needed to be tied to said section ended up grabbing the air like a scoop and destroyed themselves (hwy speed mind you). Either all or nothing, but I personally wouldn't for aero reasons. People smarter than you and I thought it was necessary, I tend to believe them
Buug95917932.50 |
11-08-2017, 05:10 AM | #9 |
Rep 18,801
I have a 1/4-drive mini air ratchet (made for under-dash work) that coupled with a 3" 1/4-drive extension bar and 8MM socket makes easy work of removing the 16 screws that secure the engine under panel. However, about two years ago I picked up a Milwaukee M12 Fueled 2453 impact gun for wood working purposes. I use that tool now more often to remove the under panel if I'm not going to fire up the air compressor for other work. The Milwaukee impact gun has 1,200 in/pound (100 lb/ft) of torque and works great for running out the screws securing the panel. It uses the standard 1/4 Hex drive tool bit configuration, so all that is needed is a 1/4 Hex-to 1/4-drive conversion bit to use 1/4-drive sockets with it. It's a compact driver tool that fits under a lifted car nicely. Works great.
Most engine compartment work requires nothing bigger than a 1/4-drive tool, so getting compact a 1/4 Hex drive impact tool will pay back very quickly. My 2 cents.
11-08-2017, 05:46 AM | #10 |
Fuck it dude, let's go bowling.
888
Rep 2,480
BMW engineers put it there to mask all that leaking oil. My garage floor appreciates it.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
9
11-08-2017, 06:19 AM | #11 |
Maximus Decimus Meridius
1131
Rep 4,586
With the proper tools, it literally takes 30 seconds to take it off though lol..
F30 335i Melbourne Red Metallic M-Sport Package |
6ixSpd6033.00 TheMidnightNarwhal2682.00 |
11-08-2017, 10:32 AM | #13 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
I bought an impact driver just to deal with underbody panels
11-08-2017, 10:37 AM | #14 | |
Rep 14,829
The other interesting thing is that both vehicles have a central jack point and again BMW does it better imho, it's metal. Lexus simply has one put the floor jack in a circle with the plastic there... But yes what a pita to check the power steering pulley, right? |
11-08-2017, 10:44 AM | #15 |
Rep 807
Drives: 2011 335is 6MT
In addition to the previously mentioned masking of oil leaks, my car's engine compartment stays significantly cleaner than my truck's which does not have one.
11-08-2017, 01:10 PM | #16 |
Sua Sponte
1299
Rep 2,850
Exactly. The same "smart" guys that designed the charge pipe, HPFP, VC/gasket, PCV system, etc.
BeastMode335i1131.00 NGEE887.50 |
11-08-2017, 01:24 PM | #17 | |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
I've seen this on a number of E46s and E39s. The car starts leaking and having a problem but the underside is dry so the driver doesn't realize until it is too late. I mean obviously watching the gauges helps too but it seems nobody has enough common sense to do that.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
11-08-2017, 02:44 PM | #21 | |
888
Rep 2,480
11-08-2017, 08:14 PM | #22 |
Rep 266
Why are people suggesting getting an impact wrench in order to get a couple of 8mm screws holding a plastic tray to the vehicle's undercarriage? Someone even boasted how the impact wrench he purchased for this purpose has 1,000 lbs of torque. lol
What next? Replace the screws after use with new aluminum ones?
2007 335i E92 FBO | MHD Stage 2+ 93 octane | xHP Stage 3 | Fuel-It! Stage 2 LPFP | VRSF 7" FMIC | VRSF Catless Downpipes | ER Chargepipe | HKS SSQV4 BOV | Ultimate Racing CAI
