Oil filter cap leaking (major). STP filter & O-ring any good?
11-08-2017, 04:47 PM | #1 |
Crazy Frog
543
Rep 1,212
Changed the oil back in June and my dumbass used an STP filter/O-ring from Autozone instead of the Mann one. Haven't had any issues with it until now.
Are STP filters that bad? The weather got colder recently, so I'm thinking the O-ring failed? The filter cap is torqued down more than enough. It's about 1cm past the green (alignment) markings. I cleaned up the leak and went for a drive. This is what it looks like after just 2 miles of (granny) driving. https://ibb.co/eHpqJG I have a Mann filter on the way, I'm just gonna to replace the o-ring to see if the leak is fixed.
11-08-2017, 05:27 PM | #2 | |
Rep 937
example http://www.bimmerfest.com/forums/#/topics/565547 |
11-08-2017, 05:59 PM | #3 |
Crazy Frog
543
Rep 1,212
Never buying STP or any aftermarket filter/o-ring brand ever again! What a piece of sh!t!
11-08-2017, 07:13 PM | #4 |
Rep 665
Leaking oil cap is 99% of the time because the o-ring wasn't place in the correct groove put pushed all the way against the cap lip.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
Efthreeoh17426.00 |
11-08-2017, 07:14 PM | #5 |
Rep 937
Yea after reading on a few threads last time I researched, our cars runs hotter and also hold oil for an extended period of time. I saw some filters that were just in pieces in the filter housing after 10k miles. So far Mann has been the only brand to hold up in our cars.
11-08-2017, 07:30 PM | #6 |
Rep 807
Drives: 2011 335is 6MT
11-08-2017, 07:55 PM | #7 |
Rep 49
When I bought my car it had this issue soon after. I assumed it was a misaligned oring so I took it apart and made sure everything was correct. Then it leaked even worse! Whoever did the oil before I bought my car used the crappy filter and the orings must have compressed and hardened over a few kmiles. Be careful til you fix it because it will leak oil all over the place including your belt which can ruin your engine.
BimmerNugget542.50 |
11-08-2017, 08:43 PM | #8 | |
Crazy Frog
543
Rep 1,212
11-08-2017, 09:18 PM | #9 |
Rep 165
I've used STP a lot in the past on my N52. Weird how this never occurred to me. Changes done every 5k. Maybe some get unlucky batches? Seal not on right groove?
@balxoscar
@1visionperformance |
11-08-2017, 09:48 PM | #10 |
Rep 18,800
I've never used anything but a BMW OE (MANN) oil filter. The MANN filter is good for far north of 17,000 mile oil change intervals. A few years ago I bought a used E85 Z4 3.0si Coupe (it has the N52) from CarMax. I immediately changed the oil in the engine because I was sure CarMax didn't use the correct oil nor filter. I was right about the oil filter. It was an STP brand and did not fit correctly; it was partially crushed. I could see how after a few thousand miles the oil filter element could degrade. Most Advanced Auto Parts stores carry the MANN HU-816 N52 filter in stock.
11-08-2017, 10:22 PM | #11 | |
Crazy Frog
543
Rep 1,212
I am praying that the new Mann Filter and O-ring will solve my problem. The oil filter cap is not cracked, so I don't see any other culprit.
