Remote Key button not able to lock car
11-10-2017, 01:51 PM | #1 |
Rep 18
Recently I purchased a 2006 325i, no comfort access. During the purchase, I didn’t realize the remote key button for lock didn’t work or not sure if it’s some settings in the car? Right now I have to manually lock it via slide out key.
The remote works fine to unlock the car and open the trunk, just not able to lock. Is it possible to have a defective lock button on the key? If so, what’s the option besides getting a new remote? Do the cheap eBay remote portion work to lock, unlock and open trunk without needing to take it to a dealer or locksmith to program it like on E46s? |
11-11-2017, 07:42 PM | #3 |
Rep 1,203
Go to autozone, they have IR testers for keyfobs to see if a signal is being sent from the fob when buttons are pressed. Perhaps you have a bad keyfob. Ebay keyfobs wont work without being programmed from the dealership or knowing someone able to do it.
11-11-2017, 08:01 PM | #4 |
Rep 13,122
11-12-2017, 12:15 AM | #5 |
Rep 18
Thanks, will try to find an Autozone or O'reilly that have the IR tester. If the buttons do work, what else can possibly be wrong with the system?
11-12-2017, 05:48 PM | #6 |
Rep 18
Alright, went to an Autozone/O'reilly and tested the remote. When pressing the lock button, the IR tester doesn't light up (no response); whereas the trunk and unlock button works fine.
Is there a way to replace the lock button on the remote? Or do I have to buy a new remote? |
11-12-2017, 06:35 PM | #8 |
Rep 18
11-12-2017, 07:29 PM | #9 |
Rep 1,203
Either finding someone online that programs keys on the side or order a new one from the dealership, I believe are your only options
01-31-2018, 12:55 AM | #11 |
Rep 4
Go to any locksmith or AutoZone, they have IR testers for keyfobs to detect if a signal is being sent from the fob when being pushed.
07-19-2018, 03:17 PM | #12 |
Rep 4
FIXED E90 Remote
remote worked fine except for LOCK button...looked at every blog about it, finally someone suggested testing IR remote at O'reilly's or Autozone. The tester lit just fine for unlock and trunk buttons but not for Lock button. I bit the bullet and opened the case with xacto knife and managed to do it without drawing blood. With case off, we tested button again...still not working. then took some tweezers and jumped the solder points and LOCK function worked!!!! BAD BUTTON !!! The computer/electronics geek I work with removed lock button with pinpoint soldering iron and replaced button with one removed from a similar $8 Ebay replacement. SUCCESS!!!
07-19-2018, 04:06 PM | #13 | |
Rep 1,917
07-20-2018, 05:06 PM | #15 |
Going topless
32
Rep 84
Drives: E93 335i, MX-5, RCZ R
OP, Now that you have a fully working remote, can I suggest that you also obtain a spare one.
If anything happens to your current key fob (lost, stolen, driven over, dropped down a drain, etc) you really don't want to be in the position that you have no way of opening/starting your car.
Philip |
