2011 E90 Door Actuator - Door wont open
11-16-2017, 03:45 PM | #1 |
Rep 106
Hello,
I am looking for help. 2011 E90, Rear Driver's Side door won't open. The actuator arm does go up and down when the car is locked and unlocked. Door is currently closed and can not be opened. I need to replace the actuator, and I have the replacement in hand. Again, the door is closed, and I have removed the door panel. Nothing that I can do will open the door, thus allowing me to remove the T30 Torx screws, remove cable linkage, and replace the Actuator assembly. How do I go about removing the actuator from a closed door. More accurately, how do I open the door when the actuator fails in the locked position? Anyone have this happen before? |
11-16-2017, 04:11 PM | #2 |
Crazy Frog
543
Rep 1,212
Drop kick the door until it opens. Then proceed with removing the plastic panel to replace actuator.
11-16-2017, 08:22 PM | #3 |
Rep 106
Fixed it.
With these symptoms, it was as simple as removing the exterior door cable from the harness and the door popped right open. It was unexpected but very welcomed! I swapped the actuator assembly in 5 minutes. Very simple to do. Thanks. Considering that I've done this, consider me an expert and feel free to ask me questions. Thank you, thank you. |
11-16-2017, 09:32 PM | #4 | |
Rep 209
Drives: 2023 M340i (Build)
