Play in steering
11-28-2017, 03:26 PM | #1 |
Rep 521
Play in steering
I'd like to know whether you guys experience the same thing with your steering and therefore whether it is normal or if something should be checked and then changed.
I have an E92 335i with 69k miles on the clock. After doing a track experience in an M4 i went back into my car on the way home and instantly noticed the difference in steering feel. M4 felt very direct whereas I can't say the same for mine. Driving along in my car I can turn the steering wheel from the dead centre about an inch left and right without the car doing anything - move the steering fast within those distances in a straight line, does yours do the same, i.e. nothing? Now I don't know whether due to the mileage and age of the car, what I'm experiencing is: A) general wear and tear B) Completely normal C) Abnormal - things to look into? Someone has suggested that these cars have this 'dead centre' so you can drive fast on an autobahn without having twitchy steering. Its the first I've heard of that. All suggestions useful. Thanks |
11-28-2017, 03:46 PM | #2 |
Rep 5,440
Drives: Beige G31 40ix m sport
Can't say I've noticed this on mine but I will pay attention next time I use my 35i which won't be until Saturday. Turn in & steering response still feels nice & sharp on mine with 106k.
You can't really compare the steering feel of a M4 to an old 335i though. Was you happy with the steering of your 35i before driving the M4?
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
11-29-2017, 03:14 AM | #3 |
Rep 466
Probably combination of two things: M4 will be razor sharp so no point in even comparing. Secondly, general wear and tear so your steering will not be the same as it was when it was new.
If it alleviates your worry, I have a very similar "dead" feel around the centre. Like you, I have driven some new high performance cars and when going back to mine, it did feel much more loose and it did worry me slightly. I even checked out the lower joint of the steering rack and it was all good and tight. Could be the tie rods are worn? Not sure. But I know it isn't something to get overly worried about! |
11-29-2017, 03:30 AM | #4 |
Rep 32
Check the torx bolt on the lower u joint. I believe it is a e10 torx. Might help a bit. I hope I didnt strip mine badly when I used a e12 to tighten it and it was too big.. fuuk
11-29-2017, 04:55 PM | #5 | |
Rep 521
I have to say I was happy with it and possibly might not have even noticed it. Unfortunately, now I'm always moving the steering wheel left and right wondering whether its something worth looking into haha -_- |
11-29-2017, 04:57 PM | #6 | |
Rep 521
Thanks, will do. Might book it into a local indy anyway just to check if it could be anything. |
12-02-2017, 06:51 AM | #7 | |
Rep 5,440
Mine is lowered though maybe that makes a difference, shocks & springs were replaced at 78k, new top mounts & Spring seats at 98k. Replacing the top mounts made a big difference to how my steering felt, apart from that everything else is original.
G31 40ix M Sport
12-03-2017, 04:12 PM | #8 | |
Rep 521
12-03-2017, 09:50 PM | #9 |
Rep 2,772
M cars have special steering rack with modified ratio to get such feeling
stock cars which ordered by spec can have active steering , in which steering rack have variable ration, on parking or slow speed it is have for example 1.5 rotation from left to right and on high speed it is have standard ratio
AD18350.50 |
Tags |
centre, dead, e92, play, steering |
