12-07-2017, 12:59 PM | #1 |
Rep 2,044
Halogen to OEM LED headlights, pls?
Hello BMW Experts!
I have a 2017 330i, with the sad halogen headlights. I would like to drop in some OEM BMW LED headlights (Regular, not adaptive), but haven't seen much info on this particular switch. Is this as easy as changing the lights (yes, drop bumper), & changing some coding? Are there certain 3-series years lights I have to use? Is there a 'harness' change? Is there a really really good write-up or YouTube on this? TIA! Murf |
01-05-2018, 08:38 AM | #4 |
Rep 6,047
The LED headlights look cool but they are not very bright. The adaptive LED lights are brighter. If you get non adaptive you may want to code them for Euro spec as that is brighter. Looking to have mine done. Also see about getting the LED fog lights as these help illuminate the road better.
01-05-2018, 12:32 PM | #5 |
Rep 4,031
Where are you getting hold of OEM ones?
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
01-05-2018, 12:34 PM | #6 |
Rep 4,031
Also I contacted Brian at Bimmertech, very helpful. I haven't pulled the trigger yet!
01-06-2018, 01:49 PM | #7 |
Rep 2,044
Hello BMW Experts!
I haven't gotten the parts yet & my knowledge is sketchy, but I think you need a wiring harness to attach the lamps. Then you need some coding to make them behave right. Optional seems to be the leveling function, which can be bypassed with coding. Otherwise you need level sensors (I think frnt & rr, ~ $200.), and the wiring harnesses for them. There are instructions for running the wiring out there on the innernet.... There is a person selling the harnesses & coding (here or on Bimmerfest), and the main harness might be on Ebay. It's been very cold here lately, so I haven't really even thought about getting this going yet. Pls keep posting! Murf |
01-06-2018, 04:14 PM | #8 | |
Rep 10,473
There is another thread from late last year with specs from NHSI showing that the non-adaptive BMW F30 LEDs are actually worse in light output than the BMW Halogens, regardless of what some other forum members have claimed and posted. Even the Adaptives were only rated Acceptable, not Good (the best rating). HID Xenons may not be fashionable but they still rule. |
01-31-2018, 05:22 PM | #10 |
Rep 2,044
I have my wiring harness on order, but it isn't here yet. When that gets here, I only need a warm day, maybe a garage....
I have non-adaptable LEDs, so don't have to install the leveling sensors. What I would like to know is, if I put the LED lights in & then can't get the proper coding immediately, what will my headlights do until then? Murf |
01-31-2018, 09:49 PM | #11 |
Rep 10,473
02-02-2018, 10:33 AM | #13 | |
Rep 235
02-02-2018, 01:22 PM | #14 |
Rep 2,044
02-02-2018, 01:26 PM | #15 |
Rep 235
I have the non-adaptive as well. Both versions have vertical aim control, achieved through a front and rear level sensor. Adaptive just have horizontal control on top of that.
02-03-2018, 10:57 AM | #17 | |
Rep 2,044
BMWOem has the leveling sensors "system" listed two ways: rear axle: http://www.realoem.com/bmw/enUS/show...diagId=33_1614 i For vehicles with Xenon Light S522A=Yes or Adaptive LED headlight S552A=Yes or LED headlight S5A2A=Yes front axle: http://www.realoem.com/bmw/enUS/show...diagId=31_0948 i For vehicles with Xenon Light S522A=Yes or Adaptive LED headlight S552A=Yes or Driving Assistant S5ASA=Yes Both pages (listings) describe the same front & rear system, but only the rear listing saying needed for plain LED headlights. I think this adds ~ $400. to the project in wire loom, sensors & brackets. Plus more work. I might wait till spring. Murf |
03-06-2018, 12:38 AM | #18 |
Rep 68
check out my post, it may help answer your questions:
http://f30.bimmerpost.com/forums/sho...ght=fog+lights Also, I am planning to convert fogs to 3000k LEDs and the front and rear signals to amber LEDs so subscribe and stay tuned |
03-06-2018, 01:41 PM | #19 |
Rep 765
I'm about to do this retrofit. I have the lights and all modules. Just study the wiring diagram on ista. U CAN code out the errors if u don't install the sensors, someone on this forum has done so. Check this out to get u started.
http://f80.bimmerpost.com/forums/att...7&d=1490600365 |
03-06-2018, 05:16 PM | #20 | |
¯\_(ツ)_/¯
537
Rep 1,000
