E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Eccentric Shaft sensor seal
Reply
      01-07-2018, 07:37 PM   #1
Gunslinger1971
Drives: 2008 328XI E92
Replacing coils and plugs in my 328xi and noticed oil leaking from this area on the valve cover. No oil on the plug itself or in the contacts so I'm assuming its just the seal/gasket.
Can this be replaced without removing the valve cover? Just pry out with a screw driver and replace?
      01-08-2018, 12:48 PM   #2
frisbeeguy
Drives: BMW,Tesla, etc.
According to the service manual, it can't be done...mainly cause there's a chance to damage the eccentric shaft sensor plug....and the bottom portion of the gasket may not line up well with the valve cover. In reality, if you are very careful not to stress the eccentric shaft sensor plug too much, you can replace the gasket without removing the valve cover.
      01-08-2018, 08:40 PM   #3
tom9192
tom9192's Avatar
23
Drives: 325i '06
I replaced mine while doing a valve cover gasket job, but you could totally do it without removing the valve cover. Just be careful removing it. Check out figure 5 here.
Reply
e90post
