N53 Nightmare - Help Please!
01-21-2018, 02:48 PM | #1 |
Rep 358
This is driving me mad. N53 330i.
What would cause a surging acceleration (when accelerating pauses for a second then surges 200-300 revs as if it’s catching up to where it should be) as you increase speed (does it multiple times through the acceleration). Not throwing no codes and at idle completely fine. Car has been suffering from intermittent misfires cylinder 3 that comes in groups then settles for a few weeks, worse with non shell v power fuel. It was fixed after a coil for four week then came back and the injector is being replaced next week (sparks are also 6 months old NGK) However it was fine recently until I was accelerating hard and about 3-4000 rpm it suddenly felt like car hit a brick wall and check engine line came on and started misfiring hard cylinders 3,4,5,6 and running really rough, cutting out as I pulled up to lights but when driving off after 1.5k rpm would accelerate not as rough. Limped to garage like that. Checked coded and showed cylinders as above but also crankshaft - inlet camshaft AND crankshaft - camshaft output correlation faults also. Reversed the car to park at garage and it became bad misfiring cutting out as soon as I’d restart the car and try reverse, and wouldn’t start till then codes were cleared. Since then car starting and running fine except this bogging / surging idle problem As I said injector on 3 is being replaced next week, but what else could it be as I don’t think a sole cylinder 3 dodgy injector will cause the surging problem especially when at idle it is completely fine!
E93 Carbon Black 330i M Sport Auto
E90 SG 330D M Sport Auto |
01-21-2018, 04:18 PM | #3 |
Rep 358
Yeah it’s an auto Mate!
So far on my hit list aside from injector are the Vanos solonoids which I’m going to inspect clean and swap around, my only other thoughts are the camshaft sensors are bad? |
