F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Installed Depo headlights, Morimoto HID's, fog lights, and clear side reflectors.
GetBMWParts
      01-22-2018, 04:17 AM   #1
timmay77
Stupendous Man
timmay77's Avatar
Drives: 2016 F13 M6 Comp pkg
Purchased my car as a lease return, it had EVERY other option EXCEPT the lighting package. I had to ditch the horrible halogens, and I really wanted fog lights. Here are the items I purchased for this project.
Headlights
https://www.uniquestyleracings.com/i...d=1023&search=
Clear reflectors
https://www.uniquestyleracings.com/i...product_id=697
Fog lights
https://www.uniquestyleracings.com/i...roduct_id=1094
HID parts
https://www.theretrofitsource.com/h7...ros-48909.html
https://www.theretrofitsource.com/hi...reselect=50553
https://www.theretrofitsource.com/hi...anbus-35w.html
LED bulbs for the fog lights
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Pig tails for the fog lights
I purchased these BMW part numbers from Rock Auto, which was BY FAR the cheapest price. These parts install into the bumper so you can install fog lights.
51118054155
51118054156
51118054163
51118054164
First thing I did was prepping the headlights for installation by retrofitting the H7 halogen bulb in the projector with the Morimoto HID kit. The pictures are pretty self explanatory. The only thing I did a little different was I removed the screws for the bulb mount and installed some very small washers so they had a little more bite on the H7 euro adapters.
2022 BMW x30i Premium
2016 BMW M6 Coupe Comp Pkg.
2003 BMW M5 ~ Twin Turbo LS swap (SOLD)
scostu1623.00
pdav9.50
      01-22-2018, 04:28 AM   #2
timmay77
Stupendous Man
timmay77's Avatar
Now for the install. There are plenty of headlight install threads and videos, so I won't go in to major detail on that. Installing the fog lights was very simple. Unbolt the old parts inside the bumper and install the new parts. Nothing magical. I made my own wiring harness for the fog lights with the pigtails, a 40amp relay, power and ground, and a turn on signal from the passenger side low beam signal on the headlight connector. So any time the headlights are actually on, the fog lights kick on. Again, nothing fancy.
With the clear reflectors, they are another easy install. Pop out the old ones, clean all of the old 2 sided tape off COMPLETELY, and install the new ones.
      01-22-2018, 04:29 AM   #3
timmay77
Stupendous Man
timmay77's Avatar
End result:
      01-22-2018, 08:08 AM   #4
thanhqtran2
Drives: 2015 BMW 328xi
Originally Posted by timmay77 View Post
End result:
Looks nice! clean install. can you take a picture of your beam pattern?
      01-22-2018, 09:55 AM   #5
timmay77
Stupendous Man
timmay77's Avatar
Thanks, I will snap a picture this evening....
      01-22-2018, 10:24 AM   #6
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
Looks awesome
      01-23-2018, 03:27 AM   #7
timmay77
Stupendous Man
timmay77's Avatar
Not at the measured 25 feet, just off my garage as I was leaving this morning....
      01-24-2018, 09:31 AM   #8
Rylo Ken
Drives: BMW 2014 328i
If possible, could you post a picture of where you mounted the ballasts?
      01-24-2018, 10:01 AM   #9
timmay77
Stupendous Man
timmay77's Avatar
I didn't take a picture of that, sorry.
I mounted them directly under the headlights and zip tied them to the frame there. There is a small cavity, which easily fit the ballast and error cancel box.
      01-24-2018, 12:18 PM   #10
thanhqtran2
Geezes that looks way cleaner than mine. Now im thinking i got a pair of defective headlights? any suggestions to get that clean of a pattern?
      01-24-2018, 12:46 PM   #11
timmay77
Stupendous Man
timmay77's Avatar
Sorry, not really an expert on HID's. Check the bulb to make sure it is properly seated in the housing?
      01-24-2018, 02:15 PM   #12
Rylo Ken
Where did you connect the ground? I just purchased the same set up you have and going to do the install myself
      01-25-2018, 04:35 AM   #13
timmay77
Stupendous Man
timmay77's Avatar
To the horn mount. I checked continuity between the horn mount and the battery ground. Works perfect. Had to snip off the ring terminal that was on it and install a larger one though.
      01-25-2018, 05:49 PM   #14
bmwchue
Drives: 2013 bmw 328i
nice are those the 6500k bulb?
      01-25-2018, 08:17 PM   #15
AMSWagon
Drives: G63
Looks more like 5500k
Car looks great, can't wait to have mine installed.
      01-26-2018, 03:44 AM   #16
timmay77
Stupendous Man
timmay77's Avatar
Correct, 5500k.
      01-26-2018, 06:49 AM   #17
bmwchue
Thanks that should match my estoril blue
      02-28-2018, 12:34 AM   #18
mhdelarosa
Drives: '12 328i Mineral Grey Metallic
What bulb did you use for the high beam? I'm thinking about copying your set-up with the TRS HID kit. Did TRS give any other details as to why they suggested the hylux ballast/canbus/amp over the H7 elite kit?
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
      03-01-2018, 06:42 AM   #19
timmay77
Stupendous Man
timmay77's Avatar
Update: 100% completely satisfied with these headlights. They are super bright and work perfect. Zero issues. I work at 4am, so I drive in the dark every morning. The 35w ballasts are plenty bright. I wouldn't change a thing.
What ever bulb came with the Depos. I did not touch the high beam bulb.
They said the Hylux unit is more reliable with European cars when it comes to code canceling.
      03-15-2018, 12:53 AM   #20
mhdelarosa
I just got this setup installed, but my beam pattern is horrible. I remember I had a hard time getting the adapters to fit nicely. It looks like you oriented the bulb with the return wire in the upwards direction. Is that right? I caused myself a lot of pain and struggle just getting the bulb to face downwards with the TRS euro adapters. I'm wondering if I just orient the bulb with return wire up that fitment will be better, resulting in a better beam pattern... curious what you may have done differently.
      03-15-2018, 04:25 AM   #21
timmay77
Stupendous Man
timmay77's Avatar
What you see in the pictures is all I can share. IF there is an "up" or "down" of the bulb, it wasn't noted to me. I installed the adapters in the best way I could. If that placed the bulb upside down, then it did. If I have a "bad beam pattern" I don't notice it. I am very satisfied with my set up.
      03-15-2018, 08:54 AM   #22
mhdelarosa
Yep your setup looks good to me! Thanks again for sharing.
f30post
