E90 N52 misfire moves cylinders
01-30-2018, 06:06 PM | #1 |
Rep 8
Woke up one morning last week and started my car and immediately noticed it was running rough. Drove down the street and the service engine soon light came on. I read the code with a cheap scanner and it was a misfire on cylinder #1. So I took it to the shop, they found injector #2 to be faulty and replaced it. Then they said the misfire showed up on #3. They ran some more tests and finally said that everything checked out mechanically (plugs, coils, injectors, compression) and they think it's the computer. I didn't want to pay their estimate to have it tested/repaired so I told them I wanted to pick it up. After they put it back together the misfire moved to cylinder #4. Has anyone seen this type of misfire before? Do you think the computer could be an issue? I actually removed it last night to do a continuity check on the MOSFETs like I'd seen in a couple of other posts but they were fine. And I didn't see/smell anything that looked remotely fried. Is there anything else I should check before sending my computer in for repair? Would really appreciate anyone's input. Anything helps. Thanks.
01-30-2018, 10:45 PM | #2 |
Rep 8
Well, tonight I had a look for myself. Did a cylinder drop test by unplugging each coil while the car was running. Once I found the problem cylinder (#4), I swapped its coil with #2. Didn’t bother reading the code, instead I did another drop test and saw that the misfire moved to #2. Bought a new coil from advance and now the car runs great. I guess the moral is don’t rely on the scanner. I’m hoping that’s the end of that...
01-31-2018, 08:12 AM | #3 |
Rep 29
I had a similar issue a couple of weeks ago... Very cold morning start, and the car idles & runs rough, with a reduction in power. Take it to the shop- Misfire on #5. Replace #5 coil and the car is back to normal for the rest of the day.
The next day- Another very cold morning start, and the car idles & runs rough again. Back to the shop to find out there's a misfire on #4. Replace #4 coil and the car is back to normal. It's been normal since the second coil replacement. The mechanic told me that after replacing the second coil, #1 showed a misfire, but after clearing the code & rescan, it never came back. |
Tags |
cylinder misfire, e90 misfire, misfire, misfire cylinder 1, n52 misfire |
