E90 rear window not going up after using one-touch
02-22-2018, 01:13 AM | #1 | |
Rep 321
I have a problem with my rear passenger side window not going up after using the one-touch function. It will goes all the way down and when I try to put it back up it won't. Same issue as this thread here
Any help would be greatly appreciated! |
02-22-2018, 06:54 PM | #2 |
Rep 1,705
Having the same issue with the same window. It will go down fine, but if it goes down all the way it doesn't go back up. Now if it goes down anywhere between 1-90% it will go back up. Only when the edge of the window goes beneath the weatherstripping
02-22-2018, 09:04 PM | #3 |
3 pedals
Rep 114
Do this using the switch on the door that has the issue:
Roll the window all the way down. Let go of the button, then hold the button down for 20 seconds. Roll the window up. Let go of the button, then hold the button up for 20 seconds. That worked for me when I replaced a window regulator last month. |
