Sport mode by default
02-25-2018, 12:30 PM | #1 |
Rep 40
Love my car. But I don't like starting out in normal Drive mode as the initial pedal response is...hmmm. .... lacking unless I push the pedal down firmly. I don't suffer such indignities if I move the lever over to sport mode...2008 335i
So here is my thought : make the sport mode the default when you pull the shift lever back in to "D" after the engine start. Slide the shift lever left to achieve normal drive mode for the highway cruising. Possible? Anyone ever accomplish this? I would imagine coding would be one way to do this, but there are a lot of clever folks here who may be able to swap wires around to achieve the same effect. Would be a great option for a Foxwell or Carley type interface. And, yes, I probably need to reset my adaptations to give a little crisper throttle response in normal drive. Have to go off line for a while. Will check back later. |
02-26-2018, 10:18 AM | #2 |
Rep 1,416
You bought the wrong car. The M3 and SMG trannys where the car goes from P to R to N to D/S sport mode.
02-26-2018, 10:30 AM | #3 |
Rep 1,416
Yeah you should have gotten an M3!
02-26-2018, 10:55 AM | #5 |
Rep 1,416
yeah the M DCT is the car the OP should have gotten!
02-26-2018, 01:50 PM | #6 | |
Rep 971
Drives: 2018 M2
CTinline-six6892.50 |
02-26-2018, 05:34 PM | #8 |
Rep 40
Tough crowd tonight. Looking to avoid the "broken wires in the shifter" phenomenon also. Unfortunately my car was not blessed with a dct. I do appreciate the feedback.
02-26-2018, 05:52 PM | #9 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
http://www.e90post.com/forums/showthread.php?t=842645 |
Drifter2090913.50 |
02-26-2018, 06:01 PM | #10 |
Rep 2,244
02-26-2018, 07:49 PM | #12 |
Rep 345
Seems like a lot of unnecesary work to not move the shifter to the left
Funda could go to better mods Plus our cars are steptronic, not sure if you knew we could “change gears” while in sport, that feature would then be gone if sport is seitch with D, because you can’t upshoft into neutral or downshift (probably gor up and down mixed up in typing this)into a non existing space |
02-27-2018, 12:55 PM | #13 | |
Rep 971
Drives: 2018 M2
02-27-2018, 02:12 PM | #14 | |
Rep 2,973
I plan to.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
02-28-2018, 02:54 PM | #15 | |
Rep 971
Drives: 2018 M2
