Sirius Activation issue
02-26-2018, 04:17 PM | #1 |
Rep 3
Drives: 2007 335Xi
I have added the sirius tuner, added it to the MOST loop, and coded it.
I see the SAT in my iDrive now and it shows the ESN #. I've sent several refresh attempts to Sirius with no success. Is it possible I have a bad tuner? I added the $655, deleted the $693, in both the CAS, and FRM, and Set SDARS to aktiv in the CAPPL module. Everything seems like it should work, but it won't activate. any ideas? |
02-26-2018, 11:29 PM | #2 |
Rep 2,773
try to code all ccc modules and sirius module using modified VO and let car sleep
03-01-2018, 03:32 PM | #3 |
Rep 3
Drives: 2007 335Xi
try to code all ccc modules and sirius module using modified VO and let car sleep ___
If I don't see any CCC module. Does it mean I have the wrong daten?
03-01-2018, 08:26 PM | #4 |
Rep 666
You did everything right. Sounds like the tuner is bad. Make sure that the antenna is hooked up properly.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
03-13-2018, 01:29 PM | #5 |
Rep 3
Drives: 2007 335Xi
finally after the 5th time, it activated and is working fine. The sirius technician told me, "Here try this and shut the car off and let go to sleep" . I came out the the car a few hours later and all was working.
Tags |
sirius won't activate |
