BMW e92 water pump hairline crack
02-27-2018, 04:48 AM | #2 |
Rep 18,801
New pump.
02-27-2018, 05:50 AM | #3 |
Rep 405
The amount of people with the same hairline crack and I'm surprised there isn't a recall or class action.
I've had 3 hairline cracks within 2 years, just waiting for the next one. OP, new pump, some JB Weld may get you by for a couple of months, but I'd just go ahead and replace. |
mohamedn444.50 |
02-27-2018, 01:03 PM | #6 |
Rep 437
03-24-2018, 01:48 PM | #8 |
Rep 1
My original water pump failed electrically June 2017, at 50K miles I had it replaced by an independent shop ($1,350.00). They put in a pump brand named Continental. This pump developed a crack and began leaking March 2018, now at 61K miles. Took it to the BMW dealer and paid them $2k for a replacement, installed. This is getting old.
The independent shop that installed the first replacement in June, said it isn't cracked when I showed it to him. I have leak testing equipment at work so I am going to prove that it does leak. Last edited by Wayneman; 03-24-2018 at 01:54 PM.. |
03-24-2018, 01:59 PM | #9 |
Apprentice
373
Rep 801
03-24-2018, 02:08 PM | #10 |
Art Collector
2427
Rep 3,450
03-24-2018, 03:53 PM | #13 |
Rep 3,060
When was it installed? If within warrenty, I'd take it to the dealership asap and fight for a replacement. If denied, I'd order from FCP along with a thermostat and DIY. Otherwise, you'll probably be stranded when it gets worse.
03-24-2018, 04:18 PM | #14 |
Rep 2,109
Turbo models' water pumps are Continental, all of them so far, OEM, rebranded what not.
N52 NA model's OEM water pump is Pierburg. It is smaller capacity but the propeller housing is aluminum cast. Continental is higher capacity but the propeller housing is plastic and prone to cracking. There is a lot threads, discussions on these in the forum. |
