Cant Narrow Down Oil Leak
02-27-2018, 09:56 PM | #1 |
Running Late
89
Rep 168
Almost a qt in 2 days. Removed the engine pans underneath and found where its streaming down TO but not FROM. The VCG looks fresh and the bolts show signs of it having been done (stripped). Based on the lower engine cover the oil drops directly around the opening for the oil drain hole which leads me to not believe thats its from the OFHG, the oil drain, or the oil level sensor. I've been under A LOT of BMW's but the e90 takes the cake, there is just way too much STUFF... turbo stuff.
I can't tell if its the oil pan or rear main seal... I'm about to just take it to an indy and have them pinpoint the cause unless anyone has any other tips or tricks? (left side of picture is the transmission) |
02-27-2018, 10:41 PM | #4 |
Running Late
89
Rep 168
02-27-2018, 11:04 PM | #5 |
V8 Bait
207
Rep 769
well, at least we are on the same page.
Broke AF
02-27-2018, 11:15 PM | #6 |
Rep 165
Drives: 2011 335is
You should try that new molygen oil. It glows green under black light specifically to track down oil leaks. Change the oil, run the engine for a bit and shine a black light until you see where it's leaking from
02-27-2018, 11:49 PM | #7 | |
Rep 159
02-28-2018, 12:39 AM | #8 |
Rep 5,016
02-28-2018, 03:42 AM | #9 |
Rep 459
I'm betting rear main seal for this one. My 2007 was leaking from exactly the same spot, and it was a real gusher. Leaking a quart in 2 days is a huge leak, much more than an oil pan gasket. Like many other guys with a failed RMS, mine was blown clean out of the engine, hence the enormous leak.
02-28-2018, 11:01 AM | #10 |
Running Late
89
Rep 168
How did you access the leak area? What should I move out of the way to be able to access it and seal it? I don't want to tackle a huge OPG job on an auction car that i'm going to end up flipping at this point. I recall from being under there that the exhaust pipes were in the way of everything.
02-28-2018, 12:01 PM | #11 | |
Rep 159
Get a large syringe and attach a tube about ten inches long. Or longer. Buy lots of jb weld. Mix and stuff in the syringe and get dirty. Put the tube as far in as possible and pump away. I then used a hanger wire wrapped in one sheet of aluminum to push in the jb where I couldn't see anything. You gotta feel it. During the cleaning, visually map the turns and contours of the pan several times. So you basically have a visual map in mind while welding. After you are done give it about 2 hours. Then do the same with a can of the right stuff by permatex. I got probably 80% if the pan for sure. That's still an increase of plugging the seal by 80%. Keep in mind that the weld is a bitch to take off if the oil pan needs to be opened for any reason. The weld should stop any leaks and the right stuff is an extra cover. When you are all done, wipe away any areas you didn't need to cover. And leave the car alone for 24 hours. Also, the oil sensor was soaked in oil. I cleaned it with mass air flow sensor cleaner and added an extra layer of cover to the wiring. Run a small amount of right stuff anywhere around the sensor you see oil. Do a good survey before you clean anything so you know where things puddle up. It might work, the whole took about 4 hours. A lot better and simpler than doing it the right way. You may have to remove what's in your way but I decided to go around everything. |
02-28-2018, 12:05 PM | #12 | |
Rep 506
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
02-28-2018, 12:15 PM | #14 | |
Rep 870
Drives: 2009 335i E90
B.O. is being more "helpful" than normal in this thread... He's probably on his troll forum now impressing all his troll friends with his abilities. But yeah, recommend nobody take any advice from B.O.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
OTO335i144.50 |
02-28-2018, 12:22 PM | #15 |
Rep 228
Rear main seal. I Went through this whole ordeal on a 335xi I had.
If the oil pan gasket was leaking you'd expect to see oil around the perimeter of the pan, passenger side (since engine slopes that way) Not saying the gasket cant leak behind the bell housing, but odds are it isn't. In my pic you can see that when the RMS leaks it drips down and follows the oil pan, leaking out just as seen in your photo. FYI I replaced the oil pan gasket first before realizing all of this. Both jobs suck on jack stands, but I managed just fine by myself. |
02-28-2018, 12:28 PM | #16 |
Rep 1,753
Lets stop these wars please... you guys are now just as unprofessional. Most of us here are hobbyist (not sure if thats a word) and not BMW engineers. So people will chime in and we have to encourage. If they are not correct about something then correct them with FACTS if you wish but lets work together instead of drifting away from the actual issue. Lets stop trolling is what i am saying.
CTinline-six6892.50 |
02-28-2018, 12:36 PM | #17 | |
Rep 506
I hate trollers and this guy won't stop so the best thing to do is troll him back ti'll he stops the nonsense or until the mods delete his account so we can all be back to a normal forum.
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. Last edited by OTO335i; 02-28-2018 at 12:53 PM.. |
MysticRob572.50 |
02-28-2018, 12:59 PM | #18 | |
Rep 870
EDIT: Sweet, just saw he's been banned. Thanks, Mods!
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. Last edited by MysticRob; 02-28-2018 at 01:47 PM.. |
OTO335i144.50 BimmerNugget542.50 |
02-28-2018, 06:20 PM | #19 |
Running Late
89
Rep 168
It sounds like my best bet is to wash the area thoroughly with brake cleaner and then start the engine and see if the leak is coming down from above the RMS to rule that out. Would that work? It sounds like the RMS would leak inside the bell housing and come out the little hole which it is not.
02-28-2018, 06:31 PM | #20 | |
Rep 228
The RMS will leak out at the rear corner of the oil pan, passenger side where the pan meets the block. It won't necessarily leak out of the bell housing because the engine is sloped so gravity pulls it to the corner. (Making it look like the oil pan) Check out my video, this was RMS leak. Losing a quart 50-100miles. Based on the amount you're losing plan on RMS. One my oil was warm and thinned It was pouring out :/ |
lab_rat394.50 |
02-28-2018, 08:40 PM | #21 | |
Rep 18,801
In specific to his claim of repairing his neighbor's OPG, anyone who has actually done the correct OPG repair (go look at my contributions to the OPG DIY), knows it is impossible to seal the pan gasket from the outside. I decided not to engage in BMW ONLY's maniacal rants on his mystical JB Weld repair because I decided not to feed him (as you so rightly suggest).
dsjr2006157.00 |
03-04-2018, 06:22 PM | #22 |
Running Late
89
Rep 168
Just a small update, I added dye into the engine and it doesnt look like any oil is coming from the RMS area... I ended up finding a pool of oil from the VCG on the intake manifold side.
