03-01-2018, 12:26 AM | #1 |
Rep 372
Do I need to get new sensors if i changed brake pads?
My dealer quoted me almost 400 to get pads changed so I’m just gonna do it myself. I’m wondering if i need to change the sensors. And a instruction will be helpful as well. Thank you!! Btw it’s a 2013 335 xdrive
03-01-2018, 06:32 AM | #2 |
Rep 603
If the sensors are not worn/cut from the rotor and if you can handle it carfully to get them off the pads you can reuse them.
(one front, one rear sensor)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
03-01-2018, 02:20 PM | #3 |
Rep 233
When I changed the rear brake pads on my old 2011 535i, I couldn't clear the Brake Fault light until I changed the sensors. They weren't that expensive and were pretty easy to swap out if I remember right. Once again that was on an F10...
03-01-2018, 02:46 PM | #4 |
No 55mph
1622
Rep 8,477
I would (and I do every time I change the pads) they are only $20 ea
If the warning light was up on the dash - then most definitely Even if the brake warning has not come up, the end of the sensor that plugs into slot of pad is plastic & gets brittle over time from heat. Sometimes they break when either pulling them out or pushing them back in the slot (fitment is very tight) At that point, during a pad replacement, if the sensor breaks you're SOL if you don't have a new set, you will have to put up with warning on dash, and then take the wheel off again to install once you get the new sensors...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-01-2018, 03:02 PM | #6 |
Rep 16,151
+1. I tried using the old one, and when the car wouldn't update it I plugged in my Foxwell 510 to try with that. It told me that the car said the sensor had been tripped and it had to be replaced to update the service interval. I replaced it (had already bought it with the pads) and the dashboard update tool worked. Don't ask me how the car knew the difference between the old sensor and the new, but it did.
03-01-2018, 03:04 PM | #7 |
No 55mph
1622
Rep 8,477
Good decision
