VO Needed !!!!
03-01-2018, 02:50 PM | #1 |
Rep 29
VO Needed !!!!
Hi guys, really need Vehicle Order to manually import into ISTA-P. After trying o recode CAS and disconnecting the battery, car won't respond to anything. ISTA-P can't read the car now and referring to vehicle order. My VIN WBAWB73587P031256. Please help if anyone has access to dealer network!
03-01-2018, 03:28 PM | #2 |
Rep 1,353
Your fa.trc file is your vehicle order.
Did you save that in INPA? If not you can always make a new file manually. You can look up the car's VO on any BMW VIN decoder site. |
mohamedn444.50 |
03-01-2018, 03:46 PM | #3 |
Rep 1,353
Your FA.TRC will look something like this...
E92_#0609&LCD3%0668*WB73$1CA$203$205$248$249$2S2$2 VB$2XA$319$403$430$431$459$481$488$494$497$4AB$4NA $502$520$521$522$524$534$544$563$570$5DS$609$615$6 20$639$645$655$688$697$6AA$6AB$6FL$6UH$760$823$840 $845$850$853$876$8S4$925$992$653-B080 However you will need to replace each of the numbers after the dollar signs above ($) with the equipment numbers you find when you perform a vin check. Go here to look up your VO using only the last seven digits of your vin. http://bimmer.work/ What you see under "Standard Equipment" and "Options" contains the numbers you need to replace above. For instance you have 226 as Standard Equipment so the first part should read like this... E92_#0609&LCD3%0668*WB73$1CA$226 The first numbers, E92_#0609&LCD3%0668*WB73 should be correct for your car already. I don't know what the battery option is on your vehicle.. The battery is the last set of numbers... There should be NO SPACES in the file... the web site is interpreting some of the numbers as space characters... Last edited by opjose; 03-01-2018 at 04:54 PM.. |
mohamedn444.50 |
