Tire size
03-02-2018, 06:32 PM | #1 |
Rep 2,367
Drives: 2011 335i
Tire size
Ik i search but can't find a definitive answer. Hav a 2011 335i with stock 18in staggered set up. I'm trying to figure out what's the widest one can go.
03-02-2018, 07:28 PM | #2 |
Rep 459
235 front, 265 rear.
Anything wider than that is likely to rub. Interestingly the e90 can fit slightly wider tires than the e92. |
mweisdorfer1906.50 |
03-02-2018, 07:31 PM | #3 |
Rep 2,367
Drives: 2011 335i
03-02-2018, 07:32 PM | #4 |
Rep 2,367
Drives: 2011 335i
03-02-2018, 09:57 PM | #5 |
Rep 552
2009 335i xDrive 6MT // Black Sapphire / Cold Weather / M Sport / PDC / Premium Package / Aerodynamic Kit / Anthracite headliner / Keyless Entry / AR Design Catless Downpipe / Style 313 19" Wheels/ OEM Euro Taillights / LUX H8 160
unrulyteach392.00 |
03-03-2018, 08:06 AM | #6 |
Rep 18,808
unrulyteach392.00 |
03-03-2018, 09:39 AM | #7 | |
Curmudgeon and Pedant
692
Rep 3,488
Someone said 235F, 265R. Think you can actually go 245 front, but it's somewhat hard to get a set within 1% circumference in that size. |
unrulyteach392.00 dsjr2006157.00 |
03-03-2018, 10:04 AM | #8 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
The e90's Speedo is off 3-4mph to begin with. Just code the speedo correction on your stalk with Carly, and you'll be fine.
unrulyteach392.00 |
03-03-2018, 06:21 PM | #9 | ||
Rep 2,367
Drives: 2011 335i
03-04-2018, 07:31 AM | #10 | |
Rep 6,968
235/40/18 - front 255/35/18 - rear Should be able to find those sizes in almost any Continental, Goodyear or Michelin. Alternate : 245/40/18 - front 265/35/18 - rear Your rear rims would need to be at least 8.5" wide to accommodate the 265 width. With profiles of 35 & 30, the roads you drive on need to be good & great condition year round or your begging for busted tires and broken rims, in my opinion. The Michelin A/S 3 plus is the very best AS tire for our cars. Continental DWS 06 is a solid 2nd. Summer tires / lots of debates, but most people here like the Michelin's. The new 4S has good initial reviews. |
03-04-2018, 06:56 PM | #11 | ||
Rep 2,367
Drives: 2011 335i
05-25-2018, 02:39 AM | #12 |
Rep 44
I need help, I just purchased 19” staggered wheels F19x8.5 & R19x9.5 both ET35. Could I run a 235/35/19 and 275/30/19 or does the rear have to be 265/30/19. stock everything too. but i’m trying to go as wide as possible but with the least effects.
05-25-2018, 02:46 AM | #13 |
Rep 940
well you didnt mention what car you drive but says xi on the side there so ill assume its awd 235/275 wouldnt be good for awd system try 235 265 or 245 275
05-25-2018, 07:02 AM | #14 |
Rep 2,367
Drives: 2011 335i
Use the tire size calculator
05-25-2018, 09:24 AM | #15 |
Rep 44
sorry for about that it’s a 2008 bmw 335xi. i really want to go with 275 rears so 245s in the front would work? I seen some people say 235 in the front but i’m confused. and is 235/265 the overall best outcome for stock?
05-25-2018, 10:32 AM | #16 | |
Rep 6,968
05-25-2018, 11:02 PM | #17 | ||
Rep 2,367
Drives: 2011 335i
05-26-2018, 12:37 AM | #18 |
Rep 44
dang i should have just kept the stock wheels on then.. i’m scared to upgrade i don’t want anything to go wrong with the stock. i wish i could go with 275s without doing anyrhing
05-26-2018, 01:23 AM | #19 | |
Rep 343
05-26-2018, 07:31 AM | #20 | ||
Rep 6,968
05-26-2018, 08:02 AM | #21 |
Rep 44
05-26-2018, 08:14 AM | #22 |
Rep 6,968
I know for a fact with a coupe even in 19" rims you will be fine. On a sedan, Idk.
