08 N52 Lifter Tick, Normal?
03-04-2018, 04:38 PM | #1 |
Rep 228
Does this seem normal or a little excessive? This is the second bmw I've owned with the N52. The other one being 06 330. With the 06 I remember the lifter tick going away after the car warmed up, and usually seemed to stay away with spirited driving.
This car is an 08 328. I just changed the oil with castrol 5w-40. The video was taken after a 40 mile drive and fresh oil change. I was sure to get the revs up past 5k multiple times. I know it's a common problem, but like I said the noise would go away on my 330, but doesn't seem to on this one. I Thought about trying the bleed procedure but doubt that will help, thoughts? |
03-04-2018, 04:46 PM | #2 | |
Rep 209
Drives: 2023 M340i (Build)
Edit: The excessive ticking for me was also right after an oil change |
03-04-2018, 05:18 PM | #3 | ||
Rep 228
03-04-2018, 06:28 PM | #4 |
Rep 2,244
The car I bought I believe had the head changed under warrantee. I think your only option is to ignore it or replace with revised head
Cruiser124119.00 |
03-04-2018, 06:50 PM | #5 |
Rep 4,330
when I got my car I had a stash of mobil 0-40 that was ll-01 certified and I used that. It was quiet.
I changed to castrol on the next oil change because it's the easiest ll01 oil to get. Tons of valvetrain noise. I changed back to Mobil 1 even though it's not ll01, no more noise. All with Mann filters. It's not like I'm every going to do a 15k mile oil change, so whatever. I suggests you try another oil. |
Cruiser124119.00 StradaRedlands4997.00 |
03-04-2018, 07:02 PM | #6 | |
Rep 228
03-04-2018, 07:03 PM | #7 |
Rep 228
03-05-2018, 12:10 AM | #8 |
Rep 5,016
Sometimes OEMs will even recommend a half quart of ATF fluid in the oil before you do your next oil change. GM did this in the mid 2000s for their LS engines that were having ticking issues.
Might be worth it after you exhaust other options. |
03-05-2018, 01:16 AM | #9 | |
Gateropode
329
Rep 2,848
As for the oil brand, I have the reverse experience than njames: M1 0w40 was -very- noisy. Castrol A3/B4 10w40 euro is much quieter. |
03-05-2018, 08:47 AM | #10 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
The early motors all do this, my 2008 rarely gets any tick - Castrol 0w40 euro blend
I also hit redline often |
10-25-2019, 02:28 PM | #12 |
Robot
1694
Rep 2,193
I bought my car with 220K miles on it and the first week I had it, it was ticking whenever the engine was idling. I did an oil change right away with Mobil 1 0w-40 and the ticking was lessened, sometimes not at all but usually when stopped at a traffic light I could hear it. I've since done three 4000 mile interval oil changes with Belgian Castrol 5w-40 and now it doesn't tick at all. I don't think the oil matters, but the cleaning properties of fresh oil at shorter intervals had to have helped.
10-25-2019, 02:42 PM | #13 |
Rep 45
Bmw changed the head casting some time in 2008 I believe. If you search enough you can find out by your build date if you have the new one.
Saw this lifter bleeding procedure. Lots of threads on this https://www.1addicts.com/forums/showthread.php?t=320299 |
10-25-2019, 03:15 PM | #14 | |
Rep 4,330
the castrol 0-40 was terrible. it does indeed seem to get loud at around 6-7K miles of oil life. so when she starts ticking I just change the oil. |
10-25-2019, 04:08 PM | #15 |
Rep 13,122
my 06 ticked a little bit when I let it set for awhile .
Went away I soon as I drove it on the highway never came back. I noticed when I switched to mobil 1 it wasn't ticking but the Engine did get quieter. Now running liquid molly 0 40 seems good so far. Also the big tick sticky heads this forum page. |
10-26-2019, 09:31 AM | #16 |
Rep 75
Lots of good responses here! I agree, here are the things that increase lifter ticking noise:
1. letting the car sit unused for an extended period of time (a week or two) 2. long oil change intervals, contaminated oil Mine is a 2007 model year build date 10/2006 so I assume it has the early version head. I have no records to indicate the head was ever replaced under recall or warranty. However, it has made it to almost 270,000 miles of service which is impressive. Car is running better after the fresh oil change. |
10-26-2019, 04:39 PM | #18 |
Rep 1,598
11-07-2019, 12:24 PM | #19 |
Rep 276
Drives: F10 M5 Comp 6-spd
This happens when the car has been driven at low revs for a while, maybe a couple of days or week. Just keep the revs up and drive it harder. My car runs as good at 206k as it did the day I bought it. My thoughts on this are that higher engine speeds increase oil flow and circulates it more thoroughly. It's a reminder to me that the car likes to RUN
2015 M5 Comp 6-spd manual
1972 2002 2003 Audi TT Coupe 225 2011 Highlander 4WD |
StradaRedlands4997.00 spyda1.50 |
01-12-2020, 11:14 PM | #20 | |
Rep 15
01-13-2020, 08:49 AM | #21 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
I didn't go through all the replies, but my 06 330i has had the revised head replaced when under warranty (many years ago) and my car sounds exactly like your does at idle after a proper warm-up. I wouldn't stress about it, my car it reaching 300k km's (187k miles) and I've been beating at the track lately and my latest oil analysis came back perfect. If there was metal on metal contact you would have seen it in the analysis.
01-13-2020, 07:21 PM | #22 |
Rep 43
Drives: BMW 328i 2007
there were issues on some of these cars with lifter noise. I looked up and read that the first thing the dealership service department would do to address this lifter noise is to hold the rpms at around 2500 for 5 minutes or more while in park.
My 2007 328i has never had this noise but my son's 2008 328i has. He mostly drives short distances and doesn't get on the highway much. So I did the above a few months ago. Sat in the driveway with car in park and revved the engine to 2500+ rpms for 5-10 minutes. Tick went away completely. The tick is back now in his engine after several months. I think it is primarily because he only drives short distances. I would make sure you have good oil in your car before attempting this. |
