Oil temperature drops from operating temperature
03-07-2018, 02:26 PM | #1 |
Rep 57
Hey guys iv got a 335is and my oil temp gets up to normal operating temperature 110c after about half an hour of highway driving but the issue that’s coming up is when I keep driving after that half hour and into 45mins-1hour my oil temperature will start to drop to 90c and even down to 80 iv notices. Any ideas why this might occur. Recently topped off my coolant reservoir with distilled water but no difference . Thanks
03-07-2018, 03:17 PM | #2 |
Rep 1,753
chances that your temperature inside a running engine is fluctuating so fast after already reaching operating temp and driven on a highway is next to ZERO. If it went up then thats another story. So i think your sensor is not good. Thats my guess with limited information.
03-07-2018, 03:40 PM | #3 | |
Rep 57
I assume your talking about the oil temperature sensor ? |
03-07-2018, 04:45 PM | #4 |
Rep 38
you have 335is which means you have dual oil cooler radiators with a thermostat. with highway cruising speeds and Toronto temps im not surprised. I live in Phoenix I drop 10 degrees if i cruise highway speed for a while.
03-07-2018, 05:11 PM | #5 |
Rep 57
So you think if I constantly push the car the oil temp will stay the same? Previously I could drive it for a couple hours and the oil temp gauge wouldn’t move. It’s odd to go from 120c and drop to 90c but if the dual radiators are working with the thermostat in this weather that makes sense.
03-07-2018, 06:40 PM | #6 |
Resident Pedant
504
Rep 792
Seems like normal operating behavior.
I had similar experiences in my M3 (which just has one oil cooler and no oil thermostat to my knowledge). Seems normal. How cold is it up there? At -5C ambient I'd see a marked decrease in "operating" oil temperatures, especially at higher speeds, like 90mph/150kmh and up.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
03-07-2018, 06:48 PM | #7 | |
Rep 57
It’s about -5 I guess at highway speeds it could be much colder... might have to wait on a warmer day to see how the temperature fluctuates |
Phyrexia503.50 |
03-07-2018, 09:24 PM | #9 |
Rep 57
Just used castrol 5w40 ll-01 a week ago.. was following bmw’s long change intervals but finally said fuck it because I saw some other posts in regards to sludge build up over time and carbon as well so I’m going to be changing more frequent every 10k opposed to their 20k intervals
03-08-2018, 08:20 AM | #10 | |
Rep 1,753
Even if you are sure its 5w-40 why would you use that when 0w-40 is available everywhere.. |
03-08-2018, 10:42 AM | #11 | |
Resident Pedant
504
Rep 792
I'm not sure if moving to 0w40 would help since you're already at operating temperate when this happens... But again I'm not an N54 guy. You've got those turbos to keep happy. |
03-08-2018, 02:57 PM | #12 |
Rep 57
Yea there is castrol 5w-40 ll-01 in the gta.. check your local Canadian tire .. the 0w-40 is also ll-01but European formula, the 5w-40 isn’t European formula, what’s the benifit of the 0w40 European formula ?
03-08-2018, 03:20 PM | #13 | |
Rep 1,753
European forumulas are 0w-30 and 0w-40 5W-40 is not approved for BMW. Not the one you buy in Canada. Even if it was in canada with -20 degrees temp i would put 0W only because all the wear happens during cold start. You want oil to flow quickly. 5w-40 does not really do as good of a job as 0w-40 W stands for winter. the lower the number the "thinner" the oil is at cold operating temp.. |
03-08-2018, 03:35 PM | #14 | |
Rep 57
I just check the castrol website. Yes it is approved LL-01 Here’s a link, check it out.. there are multiple products from castrol that are 5w-40 so pick the right one https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/E13A9F271142244680257FAA0072394D/$File/BPXE-AA5D4U.pdf .. 0 is thinner for the winter but 5w suits me just fine and it works amazing so far since spring is around the corner, might consider 0w come next winter |
03-08-2018, 04:08 PM | #16 |
Resident Pedant
504
Rep 792
Which part do you fail to understand? 335is cars have N54s with two air->fluid radiator style oil coolers, one on either side of the car, with an oil thermostat to regulate the flow through said coolers.
03-08-2018, 04:55 PM | #18 |
Resident Pedant
504
Rep 792
Ah indeed. As I said (third time now) I'm not well versed in N54s. I did think there was an oil cooler on either side, though.
Doesn't seem relevant to the discussion either way. Two oil coolers or one, driving at highway speeds in -5C is going to decrease oil temp.
03-08-2018, 05:03 PM | #19 | |
Rep 9,209
from my gauges. Is possible that the car is acting up. Eventually problem will become more obvious but usually failing thermostats do this. |
03-08-2018, 05:53 PM | #20 | |
Rep 57
So you have a link in regards to the thread you have mentioned above, I notice in past winter driving conditions that the car would maintain normal oil temperature and not drop so it was odd when I noticed that the oil temperatures were fluctuating. Thanks for the input |
03-08-2018, 06:12 PM | #21 | |
Rep 9,209
http://www.e90post.com/forums/showth...3#post22723453 http://www.e90post.com/forums/showth...828362&page=54 -20c oil was 90-95. -10c oil was 100. |
03-08-2018, 06:38 PM | #22 |
Rep 57
[QUOTE=feuer;22887514]Here you will find some photos:
http://www.e90post.com/forums/showth...3#post22723453 http://www.e90post.com/forums/showth...828362&page=54 -20c oil was 90-95. -10c oil was 100 If the thermostat is in the progress of failing do you think there might be a code in regards to it failing? Does it completely fail when it stays open or closed? |
