Advice on radio needed?
03-09-2018, 08:28 PM | #1 |
Rep 10
I have a 2006 325i with the usual radio display/fading pixel issue. Dealership quoted $731 to replace radio unit (part 65-12-9-130-046) and $220 for labor. I've seen the unit online as cheap as $500.
Question - would you a) replace with a new radio and pay the $500, plus labor. b) replace with a used radio (I've seen them on Ebay for as low as $100 from auto salvage sellers). If I get a used, will it involve reprogramming, etc.? Is this difficult to do myself? I'm fairly handy. c) try an aftermarket radio. If so, which one? Thanks for any suggestions/advice. |
03-09-2018, 08:44 PM | #2 |
Rep 13,122
You can buy a Diy kit for the LED strip for 100 bucks on ebay or send
it in to one of the places that replace the LED strip for around 150 also on ebay. You may be able to reprogram a Radio with a K/D can cable in an 06 in models after 09 it requires a Icom cable . You will need to learn BMW coding to do this. see coding subforum. There are also coders that offer remote services or if you are near a metro area you may be able to find one locally. Its easier to replace the display. see the following links. This is a very common problem. Repair resources http://cgi.ebay.com/ebaymotors/BMW-C...ioQ5fVideo#ht_ http://www.e90post.com/forums/showth...ighlight=pixel http://www.diyparadise.net/bmw_cd73_repair.html http://www.e90post.com/forums/showthread.php?t=1306708 http://www.bimmerfest.com/forums/sho...d.php?t=761513 Last edited by ctuna; 03-09-2018 at 08:58 PM.. |
03-10-2018, 07:49 AM | #3 |
Rep 1,579
Reach out to https://www.bimmergeeks.net/ They were helpful when I put a 2011 radio in my 2006. I have also changed the screen in the older radio which does not require coding. In the end I prefer the 2011 radio because it has HD radio, faster channel changing and better screen which does not fail. 2009+ radios are a made by a different company.
Removing the radio is easy. Pull up on the trim at the bottom and remove it. Remove 2 screws. Remove radio. |
03-10-2018, 08:08 AM | #4 | |
Rep 10
03-10-2018, 10:34 AM | #6 |
Rep 13,122
If you are going the new radio route you might try to get one
with USB. Coding a new radio into an 06 can require some tricky programming. http://www.e90post.com/forums/showthread.php?t=687463 |
03-10-2018, 02:30 PM | #8 | |
Rep 1,579
03-10-2018, 03:01 PM | #9 |
Rep 18,801
Okay, here's my dumb question...
Can you drive the car without the radio present in the car? My thinking is, it will throw some trouble codes, so no big deal there, but my real concern is does it cause functionality with the gauge cluster, etc.? I'll probably send my radio out to get repaired, more because being an old fart, my hands aren't as steady as they used to be. I fixed my $17 headphones a few months ago and realized my previously decent soldering skills have deteriorated a bit. TIA
03-10-2018, 04:30 PM | #10 |
Rep 2,773
you can drive car without radio but if you have rear pdc, you will not get their sounds without radio
Efthreeoh17427.50 |
03-10-2018, 11:54 PM | #12 |
Rep 637
Drives: e90 n54
As others have said replace leds
LOST BUT NOT FORGOTTEN 2009 E90 335i AW... Black grills/jb4/lux angel eyes/clear side reflectors/and a few more small mods
2011 e92 335iSSSS Black |
03-13-2018, 05:02 PM | #13 |
Rep 1
are there any aftermarket kits that integrate the back up sensors and factory amp with aftermarket stereo, I have original stereo but the led are busted, is it better to get new radio are all radios programmed just for a single car?
03-13-2018, 10:35 PM | #14 |
Rep 13,122
They are programmed for the options you have in your car .
There are a limited number of configurations . So it could be programmed for. Pro Radio or Idrive Hi Fi , logic 7 or base system. PDC sat radio or DAB in the Europe SOS Bluetooth hands free phone Bluetooth music on models with idrive after 2010 The Dynavin and some of the Andriod Clones have PDC. Dynavin N7 is currently the quality one of this group. There are complications with all aftermarket head units. Go to the stereo subforum and start looking. |
