04-10-2018, 09:09 AM | #1 |
Rep 450
Front Struts Collapsing
Hi All,
I have a 2014 F32 428i xDrive with aftermarket rims (specifically Aodhan LS007 18" (18x9)). I heard back from the dealership today after doing my last check before my warranty expires and they told me my front struts are going to collapse soon because of the the rims he says my car should has 18x8 and anything bigger is going to mess up the suspension. What do you guys think? What should I do in this case? Let insurance replace it (cause will be potholes). Go aftermarket? To support the aftermarket rims?
2014 Black Sapphire Metallic F32 428i xDrive M Sport | Gloss Black Striped Dual Slat Kidney Grills | CF M4 Style Mirror Caps | CF M4 Style Trunk Spoiler | CF Rear Diffuser | Rohana RFX5 Gloss Gold 20" | CF Wrapped Interior | BM3 Stage 2 93 Agg Tune | VRSF Catless Downpipe | Evolution Racewerks Chargepipe | Pheonix Racing Intercooler | K&N Drop In Filter|
04-10-2018, 09:30 AM | #2 | |
Rep 1,232
sounds like a bunch of bs to get some money from you, dumbest shit ever, don't go back to that SA or dealership
04-10-2018, 09:38 AM | #3 | ||
Rep 450
If what he's saying is true and my struts are failing, how can I make sure and what would I do from there.
04-10-2018, 10:26 AM | #4 | |
Rep 1,597
04-10-2018, 10:32 AM | #5 | |
Rep 1,232
04-10-2018, 10:37 AM | #6 | |
Rep 891
Wheels causing your shocks to wear out is plain nonsense unless the offset is wrong and it is physically impacting the strut. The OE shocks in the F cars wear out quicker than any car I have ever owned. I replaced mine with KW V2's at 60k (704 suspension) and literally, all of them were seeping and had barely any compression or rebound performance left. For what it's worth, my car rode more harshly on the worn out shocks than the KW's. I'm not sure how he thinks changing your wheels would help a failing strut, that's like getting a foot surgery to cure a meniscal tear.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
04-10-2018, 10:38 AM | #7 | ||
Rep 450
I also live in NY so potholes here are bad, he said this may be the cause too, or a combination of both. I am not even considering letting them work on my car anymore because my warranty is up, I just made this post to get more iinfo and see if i even have to do anything.
04-10-2018, 09:50 PM | #8 | |||
Rep 891
Indy's in our area can be very good.
04-10-2018, 10:14 PM | #9 |
Rep 776
You can buy 20" wheels for your car directly from BMW. Maybe your roads are wearing the car out, but your wheels are not. Maybe the Service Advisor got some bad info from a bad tech, but either way, it's BS.
M240i | Mineral White | Coral Red
04-10-2018, 11:44 PM | #10 |
Rep 450
So 20" rims fit just fine on stock suspension? I just have to find the correct offset ?
04-11-2018, 07:55 AM | #12 |
Rep 891
Not for a masochist
I wouldn't run any more than an 18" in NYC, OP. Any larger and you're asking for cracked or bent wheels and wallet (again).
04-11-2018, 08:19 AM | #13 |
Rep 16,151
I got 17s specifically to handle NYC potholes, and I don't even live there, I just visit regularly. The last thing I need is to bust a sidewall and/or bend a rim 5 hours away from home.
04-11-2018, 12:37 PM | #14 | |
Rep 776
https://www.shopbmwusa.com/PRODUCT/3...-FORGED-WHEELS So yes, 20s fit.
04-11-2018, 01:59 PM | #15 |
Rep 4,373
this thread is all f'ed up.
starts off about a dealer saying your 18x9 wheels are blowing your struts and how the roads and potholes in the area are really bad somebody mentions 20's out of the blue and now you're interested in 20" wheels in an area where you wouldn't want them. |
04-11-2018, 02:07 PM | #16 |
Rep 450
I never said I was interested in 20" wheels.... I'm just taking in the information I'm getting from this thread, so I can go back to the dealer and tell him what I know... alohasurftoad If you have nothing relevant to add to this thread get off of it.
04-11-2018, 06:54 PM | #18 |
Rep 100
Such bs I cant even believe those words came out with a straight face.
And if your shocks are failing and your still under warranty shouldn't they replace them? |
04-11-2018, 07:08 PM | #19 | |
Rep 450
He said since the struts failing are caused either due to the aftermarket rims or NYC potholes those are not covered. Honestly I might just go the coil-over route, if i ever see my ride quality going down.
05-05-2018, 08:02 AM | #20 | |
Rep 1,348
The pothole insurance thing is the biggest racket that is going on for them to get a lot of money from the insurance company. Just been through it. To be honest after all the money they charged the insurance company to fix my car it still has this terrible clunking noise it originally had prior to them raping my insurance company. In spite of claimed changing shocks,springs,hubs and one control arm, car still handles sloppy as hell in sport mode and worse in comfort mode, car still has annoying loud sound it had before when going over speed bumps. Rims will never and could never do what they are trying to tell you. Taking the damn car back this week coming.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
05-05-2018, 08:32 AM | #21 |
Rep 16,151
The larger the rim the shorter the sidewall. Rubber and air combine to absorb shock, aluminum doesn't, so yes, the larger the rim the greater the potential for both wheel, tire and suspension component damage from bad roads. However, 18 inch rims aren't large enough to be problematic. Wider than stock rims aren't a problem so long as the wheels/tires still have sufficient clearance. Since $6k for front struts is at least $4k more than they should cost the dealer's intent here is pretty clear.
