Is my car still remapped? (325d and 330d owners in midlands)
04-10-2018, 07:24 PM | #1 |
Rep 206
Last year I had my N57 powered 325d remapped to over 300bhp however I think my remap may have been wiped off by BMW when it went into them. At the time of getting the car back, I brushed it off as me getting used to the power but the more I think about it the more it seems likely they did. The company that remapped it don't mind redoing it if it has been wiped, but I would like to test it out somehow before i take it to them because it would mean arranging a day off work to sort it. Also if I get there and they find no problem they will charge me for the investigation.
I'm wondering if anyone has a standard 330d or a N57 325d in the midlands area and would be willing to help me find out if my car is actually still remapped or not? Failing that I would need to get it on a dyno locally to see the numbers. Or does anyone know any numbers I could be aiming for when it comes to in gear acceleration such as 30-70 or 50-70. I timed a run to 60 at arpund 6.5s but wasn't entirely accurate. |
04-11-2018, 03:18 AM | #2 |
Rep 2,003
Drives: F30 335d
What's the price for a dyno run?
What's the price the remapper will charge for the investigation if remapping not needed? Go with whoever is cheaper.
if I've helped - an Appreciate would be, er, very appreciated!
04-11-2018, 03:26 AM | #3 |
Rep 1,018
go for a set gear in M and set speeds and post it up, i got a remapped 325d and can compare.
turn off the traction, does it spin up the rear wheel easily in second away from junctions ect? (depends a bit on tyres) |
04-12-2018, 01:20 PM | #4 |
Rep 828
Mine is remapped, though I have no idea who it was done by or how much it's putting down but here's a 0-60 and 60-80. The 0-60 is such poor quality but it does seem to be around the same time as you've stated, it was in DS mode with traction control on.
0-60 60-80 |
04-12-2018, 03:33 PM | #5 | |
Rep 5,440
Drives: Beige G31 40ix m sport
I
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle Last edited by Chappers 71; 04-12-2018 at 03:57 PM.. |
04-12-2018, 04:13 PM | #6 |
Rep 828
04-13-2018, 06:50 AM | #10 |
Rep 2,026
o-60 times totally depend on ...tyres.road conditions/driver/etc...and the person who is timing it,,need a proper guage to do it properly..seen folk do it and be out by nearly 1 second
04-13-2018, 06:51 AM | #11 |
Rep 828
I don't know if it's just me but I was having a look at some 0-60 pulls with descriptions stating a 300hp remap and all the cars seemed to hit 60mph in 6ish seconds?
04-13-2018, 06:57 AM | #12 |
Rep 2,003
Drives: F30 335d
All this speculation, I gave a reasonable answer in post #2 - or so I thought.
04-13-2018, 08:33 AM | #13 | |
Rep 599
Put an accelerometer in the car and put it on a drag strip and do a number of timed runs then look at the mean value and you might be getting there. Getting back to the OP's original post, if you were used to the power of your remap, the minute your ECU is set back to standard map it would be immediately apparent. I have set mine back to standard map with the bluefin unit before and it's a totally different driving experience. |
04-22-2018, 06:59 PM | #15 |
Rep 206
I wouldn't mind taking it on a dyno, just so I could see if the car is still running the same as it was when I initially had it mapped but I don't know of anywhere local and open on weekends that offer this.
I did some timed runs with a stopwatch, these are rough figures: I was in manual mode with DSC off 20-50 in 2nd gear 4.2s 30-50 in 3rd gear 4.2s 30-70 in 3rd gear 7.3s 40-70 in 3rd gear 5.7s |
