04-18-2018, 07:38 PM | #1 |
Rep 3,722
DIY Dent/Rust Repair and Body Work
I'm not going to go into too much detail since I followed ChrisFix's instructions to a T along with the instructions for the paint I used. I'll link the video at the bottom of the thread and go over the basics.
Wanted to share to show this is possible and doable for a newbie with zero bodywork skill. This is my wife's Mazda 3. Damage was caused by a rouge poll in a parking garage, she never stood a chance Goal of the project was to prevent rust and try to get the car looking a little better without blowing, at the very least, her $500 deductible at a shop. I also wanted to do it in a way that wouldn't impair a professional from fixing this "properly" in the future, if we became interested in that. Stuff used:
Total cost for everything expendable: $80 (not including cost of reusable tools) Here's what I started out with - you can tell how far in it was pushed and how much creasing there was in these pictures: Mazda3DentFix Mazda3DentFix Mazda3DentFix First step was using the wire brush to get down to bare metal. Then using the heat gun and hammer with a long screwdriver I did my best to pull the dents and reshape the metal in a way that it wouldn't pop back or move when touched. Mazda3DentFix After that, it was time for the fiberglass body filler to get enough material to have a strong backer and fill the dents. Then after sanding down some of the glass I did the first layer of bondo, followed by sanding. Then more bondo. Then more sanding. Then more bondo again, followed by additional sanding, and then sanding some more. Finally, sanding again.... and then a little more. All to try and get the shape of the body back and correct the lines that were gone or creased. Mazda3DentFix Mazda3DentFix Mazda3DentFix Mazda3DentFix Mazda3DentFix Mazda3DentFix Eventually, when I decided I needed to stop sanding or I would be at risk of becoming part of the car, I decided to start the painting process. WHICH MEANT... more sanding. This time with a higher grit in prep for the paint. A couple coats later and I was wet sanding the primer to prep for paint. Mazda3DentFix Mazda3DentFix The paint came in 4 stages:
This next picture is after just one decent coat of groundcoat. After a couple more coats I added the flake, and then sat around for half an hour as it dried. Mazda3DentFix Mazda3DentFix Mazda3DentFix Finally I applied the clearcoat and let the car sit overnight before peeling away all the protective plastic and tape to reveal my work. If you look close or were told the car was damaged you'd be able to pick out some inconsistencies in the body filler, but for $80 and having never done anything like this before I'm extremely happy with the results. The paint is fixed, the body is 90% better, the seams are sealed and painted, and there's no chance of rust now. I still need to wet sand and polish the clearcoat once it fully hardens to bring out the flake and glossiness. The paint matches pretty decently despite the bumper being a bit faded. The car is filthy still since I have to wait to wash it but it looks pretty good even before polishing! Mazda3DentFix by Matt Steele, on Flickr Mazda3DentFix by Matt Steele, on Flickr Here's ChrisFix's video on how to fix rust that I used as a guideline for this project, I don't think I would have even considered attempting this if I hadn't watched his video first.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-18-2018, 08:00 PM | #3 |
Rep 3,722
04-19-2018, 08:37 AM | #4 |
Rep 2,476
Drives: Satan's Chariot 2.0
Good work
04-19-2018, 10:43 AM | #7 |
Fleet Mechanic
13243
Rep 1,975
Drives: E86 3.0si
Garage List '19 VW Golf R [10.00]
'55 Ford F100 [0.00] '08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [9.50] |
I'm impressed. Nice job.
04-19-2018, 12:31 PM | #8 |
Yoda of mods
1698
Rep 3,007
Drives: X5 RWD
Fantastic job.
04-28-2018, 12:09 AM | #12 |
Rep 3,722
What would you do for something like this? Cut away damage/weld in new section from donor?
05-07-2018, 06:22 PM | #15 |
Rep 1,882
Pull/hammer straight, apply less than 3mm of filler to smooth out the metal repair, seal and paint. We never ever use any fiber filler for repairs, it will crack and fail.
05-07-2018, 07:03 PM | #17 |
Rep 1,514
Tags |
body, dent, fix, repair, rust |
