What on EARTH is this steering issue??
04-20-2018, 01:37 PM | #1 |
Rep 358
Does it only on full lock to left. Really irritating now. Sometimes throws the wheel back with force if try to hold against lock. Occasionally I get heavy steering randomly when driving, completely back to normal as soon as you restart the car
E93 Carbon Black 330i M Sport Auto
E90 SG 330D M Sport Auto |
04-20-2018, 07:18 PM | #2 |
Rep 828
Sounds like a power steering issue, also when you full lock the steering try not to keep it there or force it in any way as generally speaking it can cause damage. The first thing I would suggest is check the the power steering fluid level, at the same time also check the power steering fluid itself. If it is ATF it is red in colour, if CHF11S it will be green, worn fluid turns brown and darkens more as it's left. The third thing is the power steering pump itself but I have a feeling it may just be down to the fluid
04-20-2018, 07:46 PM | #3 | |
Rep 655
04-21-2018, 01:54 AM | #4 |
Rep 358
I rarely ever full lock the car only held it there for the purpose of demonstrating in the vid
As for the fluid that was my initial thoughts too, however the E93 comes with Electric Power Steering as standard (I realised this when I couldn’t find any power steering reservoir in the engine bay), does that leave the pump or steering rack? (Unless I’m being daft and just can’t find the reservoir?) does the electric power steering still use fluid? |
04-21-2018, 04:26 AM | #5 | |
Rep 828
04-26-2018, 04:45 AM | #8 |
Rep 94
Some cars have the optional 'active steering' too, I don't know much about it but would be worth finding out if you have the standard setup or active.
2010 E91 320i MSport
VW Corrado VR6 |
04-26-2018, 10:12 AM | #9 |
Rep 655
here is the pic of the steering unit electric, I would say have a friend help you out and turn the wheels while you are looking under the car and try to check if the motor is making that noise. Not sure how electric steering behaves when you turn to the max.
04-26-2018, 10:29 AM | #10 |
Rep 378
I had the intermediate shaft go bad caused slimier steering issues, felt bound up at certain positions, not all that uncommon I understand.
