Is this oil on the exhaust manifold?
04-28-2018, 05:23 AM | #1 |
Rep 828
Hi All,
cars been off the road for some time and I started it up a while back and I noticed some smoke coming down by the DPF area. I didn't think much of it as it had been stood for some weeks and it cleared after a few minutes, I then decided to take a quick video around the area as I was told when the turbo was replaced that the rocker cover gasket was saturated in oil but not leaking. So i took the video and I noticed this in the video: Here's the video I originally took. I've watched the video a few times and despite being able to see the top of the manifold also being saturated I can't actually see it coming from the rocker cover? https://youtu.be/bp--FFZVnwk |
04-28-2018, 06:53 AM | #2 |
Rep 2,476
Very possible it is the rocker/valve cover. It's a very common leak point. The gasket is rubber, so if it "looks saturated", it's leaking. Keep in mind, these valve covers themselves like to crack and leak, as well, not just the gasket. Also, with the engine being angled towards the right side of the car, that's where the leak will occur/show first.
04-28-2018, 07:31 AM | #3 | |
Rep 828
04-29-2018, 05:53 AM | #5 | |
Rep 828
https://www.newtis.info/tisv2/a/en/e...th-lid/I6HyAmX I'll probably start on stripping it down today just so I can see whether the injectors might rotate and then pull out without the need for an injector removal tool, it will also be good to give them a clean, can't imagine what they look like 148k in haha. |
