05-21-2018, 06:27 PM | #1 |
![]() ![]() ![]() ![]() ![]() 1,048
REP 638
Tool me, school me
So socket set's.
I had fun with the BMW this weekend... Anyway , trying to work out if I have a 1/4" 1/2" and the wrong extenders not fitting, and having to get adapters and all that kinda crap... So, let's take it slow in baby steps, assume I know jack LOLZ I'm trying to arrange my tools so why 1/4 3/8 1/2 3/4 I'm guessing the bigger "number" gives better torque, I kinda also understand dif between 6 ptr and 12 ptr sockets, but why is ther 12 (or is it 16) if 6 gives better grip Should I get 2 full socket set's I think I have a mixture of a "big" one and a "Small" one , so I'm guessing 3/8" and maybe a 1/2 (or 3/4") Not worried about makes, just trying to get my head round what I need, how to organise it and why ? LOLZ txs |
05-21-2018, 07:39 PM | #5 |
![]() 1,225
REP 2,476
3/8" drive is by far the mostly used, followed by 1/4" and then 1/2" not too far behind...but, I feel all 3 are necessary.
1/4" for nuts/bolts ranging from roughly 13mm and smaller. 3/8" for the 10mm to 17mm range. 1/2" for things larger than 17mm. Things overlap sometimes, and you may find yourself needing the leverage of a larger/longer 1/2" ratchet, with a smaller socket. Things like brakes and suspension work would be examples. SK makes some really good sets that fall in line between Craftsman and Snapon pricing, yet are really good tools with lifetime warranty. I've had mine for over 20 years and they're still going strong. They're also all 6 point. Of course, you now also need a good E Torx set and 1/4", 3/8" and 1/2” torque wrench set more than ever before with all of the aluminum and yield to torque bolts used these days. |
jaye9441048.00 |
05-21-2018, 08:27 PM | #6 |
![]() ![]() ![]() ![]() 252
REP 439
Since your in Canada i will recommend you get this. It will have everything you need except a tool box for the sections it has but you can just put it back in the cardboard. I bought this when i was starting college and it will have essentially every tool you will need (depending on what you want to do)
http://www.canadiantire.ca/en/pdp/ma...-0589295p.html ignore the price it is very commonly on for $249 - 299 instore or in some cases as low as $199
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
jaye9441048.00 |
05-22-2018, 06:43 AM | #7 | |
REP 638
great explanation !
05-22-2018, 06:47 AM | #8 | |
REP 638
Looks like a good set, 749+tax
I'll keep a watch on it. I would have about 1/2 - 3/4's of that stuff, I just bought a round of tools recently so the socket set/sets is what I'm trying to concentrate on, especially (as I said) after my "fun" time with the BMW Quote:
05-22-2018, 08:30 AM | #9 |
![]() 13,066
REP 1,965
I used to be a purchasing coordinator for a company and my entire job was purchasing tools. All the recommendations here have been spot on. I can't really give any further input that would compound anything stated above. If you get to where you are needing wrenches and don't mind spending the money on a set that you will really enjoy working with check out Wera Joker series I've actually had a hard time finding anything that Wera makes not to be great. Amazing tools.
05-22-2018, 08:51 AM | #10 |
S.FL S65 Specialist
4,138
REP 4,128
I bought these trays from Harbor Freight, and been trying to fill them up.
Do you need everything in all sizes? No, but it's helpful for certain jobs. Few recent additions not shown in this pic. ![]()
05-22-2018, 09:04 AM | #11 |
Coming Soon
![]() 253
REP 960
Just get a good craftsman set. Its a perfect place to start
http://www.sears.com/craftsman-230-p...2&blockType=G2 |
05-22-2018, 09:11 AM | #12 |
S.FL S65 Specialist
4,138
REP 4,128
$450 for an 11 peice metric set?
https://www.amazon.com/Wera-05020091...rds=Wera+Joker Unless you are a professional mechanic, I don't see any normal person spending that much on a set. They do look great.
jaye9441048.00 |
05-22-2018, 09:50 AM | #14 | |
![]() 13,066
REP 1,965
I disagree. You can literally bend a pair of their pliers by hand. The people I bought tools for were completely against using anything Kobalt. I will say that I have a set of the Kobalt Extreme Access sockets and they are amazing. The sockets fit metric and SAE to reduce the number of tools needed and there is no need for shallow or deep well, they fit everything as the bolt passes through the middle. Aside from these tools I avoid anything branded Kobalt. I'm not a big fan of Craftsman anymore either. After 5-6 years ago they seem to mass produce garbage. Last edited by King Rudi; 05-22-2018 at 10:00 AM.. |
05-22-2018, 10:15 AM | #15 |
![]() ![]() 1,087
REP 1,912
I use almost exclusively 3/8. A 1/2 ratchet with a 1/2f-3/8m adaptor will get you out of many troubles too.
Don't waste your time with Craftsman, they moved their manufacturing to Asia a few years ago and quality went way down but the prices stayed the same. Still OK tools but Harbor Freight or Northern Tool are an equivalent tool for cheaper with the same lifetime warranty. You do get what you pay for with tools, but those should be good for most home DIYers. Buy a set and replace the high-use ones (8, 10, 12, 14, 17) with better as they get lost or fail. Get 6 point, I hardly ever see 12pt fasteners and I've been doing this for a long time, all 12pt sockets do is round off 6pt bolt heads. Some BMW spark plugs are 12pt 14mm deep socket with a thin wall profile. Get the schwaben socket, it works great and some of the others are too thick to fit. Spend some extra money on the following: -Frequent use tools like ratchets -"Oops" tools- stripped bolt extractors, thread chasers, breaker bars, basically anything that's going to get you out of a bind. -Tools specific to your car (check out OTC tools and assenmacher for a lot of the euro car tools) -Diagnostic tools and measuring tools, for God's sake I can't believe the number of people who cheap on these things, how are you going to fix it if you don't have an accurate measurement to begin with! A good multimeter is especially important. Last edited by PINeely; 05-22-2018 at 10:31 AM.. |
King Rudi13066.00 |
05-22-2018, 10:49 AM | #16 | |
Hoonigan
![]() 6,947
REP 3,017
Drives: '09 328i, '98 Wrangler
Craftsman is garbage now. Their older stuff was really just okay, but all the newer tools are made in China, especially their "evolve" line. I had one of the 3/8" evolve ratchets and the mechanism broke inside while I was tightening something, causing my hand to slam against a suspension component on my Jeep. I never threw a ratchet so far, haha. Sears would only replace it with an even cheaper looking beat up ratchet. I went on ebay and bought a used made in USA S/K tools ratchet in great shape for $8. Most of my ratchets are now S/K, older craftsman, or a 1/4" set from Autozone that I use once in awhile. I use my DeWalt battery impact for most things now.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
King Rudi13066.00 |
05-22-2018, 10:52 AM | #17 | |
Hoonigan
![]() 6,947
REP 3,017
05-22-2018, 12:21 PM | #18 | |
![]() 13,066
REP 1,965
BM235iW97.00 |
05-22-2018, 12:44 PM | #19 |
![]() ![]() 3,831
REP 5,776
What I have found is buying decent tools is always a good investment. You don't necessaily need to go out and get a huge set all at once.
Add tools and parts as you need them. Certain torx sockets like the one for removing the strut brace are specialty as is the spark plug socket. I was installing wheel spacers yesterday and took off my wheels until I got to a wheel with a semi stripped bolt. I was using a 12point 17mm with breaker bar. The wheel lugs are 6pt which I don't own. Borrowed a neighbor's 17 mm 6 point and snapped it. Ended up going to a gas station to have a friend loosen it with a pneumatic 6pt. So, no matter what you plan, you never know when something else is needed. |
jaye9441048.00 |
05-22-2018, 01:09 PM | #20 |
REP 638
05-22-2018, 01:42 PM | #21 | |
![]() 125
REP 168
King Rudi13066.00 |
05-22-2018, 02:00 PM | #22 | |
![]() 13,066
REP 1,965
