Helicopter at 60mph
05-25-2018, 11:51 AM | #1 |
Cruiser
Rep 4
Helicopter at 60mph
Hi all
So I hit a pothole about 2 months back, hard enough to puncture the tyre involved. Got that fixed and thought that might be about it. Since then as soon as I get to 60mph there's a lot of throbbing, helicopter-esque noise from the wheel in question which gets a bit better with speed but not much. I got around to having the alignment and balancing looked at, which hasn't fixed the issue, but the garage said that the wheel is slightly buckled which may also cause the noise/judder. Before I shell out on alloys, is there anything cheaper I should be looking at in the suspension or in that general area that could be causing this issue? Thanks in advance! |
05-25-2018, 12:44 PM | #2 |
Rep 5,440
Drives: Beige G31 40ix m sport
You could also consider having the wheel repaired if it's only slightly buckled
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
05-25-2018, 12:57 PM | #3 |
Rep 323
Front or rear wheel? I assume its a front wheel so if you are running squared wheels (ie not staggered) then you could try that wheel on the rear where you wouldn't feel it as much and that will tell you if its the wheel or something else (If the wheel is buckled though its likely the problem)
Instagram @Jay4000
05-26-2018, 05:13 PM | #5 |
Rep 27
05-27-2018, 11:12 AM | #6 |
Cruiser
Rep 4
Thanks all - having had the alloy looked at and de-buckled (unbuckled? Not sure what the verb is here!) The problem is still there, So caliper will be my next port of call.
05-28-2018, 02:53 AM | #7 |
Rep 109
Wheel bearing?
Ex E90 325i - BMW Performance Chassis Kit | BMW Performance Gearknob & Handbrake | Darklines | K&N E-2022
Current E92 320i - K&N E-2021 |
06-25-2018, 03:38 AM | #9 |
Cruiser
Rep 4
