05-28-2018, 11:34 PM | #1 |
Rep 1,466
Northern CA / Bay Area Fuel - Potentially Serious Issue!
Over the last couple of weeks I've been looking at datalogs of my car with various BM3 OTS maps, and also with the stock map, and I'm finding a very worrying data point.
I've documented a lot of this in another thread, so I won't repeat all the data here, but to summarise: I was finding 'Knock Detected' events in my data log with the Stage 1 91 octane OTS BM3 map, so I switched back to stock, logged again and found similar 'Knock Detected' events with the stock map.I know that CA (or ACN - Arizona, California, Nevada) fuel is known to be not as good as the rest of the country, but 88 performance when being sold as 91, is that even possible, or legal? I also know that there are a few forum members (e.g. UltraMagneticAL and tehboost) who are based in Southern California, and anecdotally appear to have 91 AKI fuel that isn't quite as bad as in the bay area. My larger concern, is that our cars were designed to run on 93 AKI, and say 91 AKI minimum inside the fuel door and the owners manual. I'm seeing 'knock detected' events A LOT with standard pump gas on the stock map, which isn't a good thing. I'm actually worried that the fuel in the bay area may be causing long term damage to forced induction cars even without any modifications, and owners are simply unaware! There are three main oil refineries in the bay area:
I guess it should be obvious that Chevron stations are using gas from the Chevron refinery, Shell from Shell and Valero from Valero, but what about the others? 76, BP, Mobil, Arco, Costco, Independents etc. Does anyone know if there is a way to have gas tested? I'm serious enough to say that there might be a class action law suit that could come out of this, if it's found that we're being sold under performing gas.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings |
05-29-2018, 05:52 AM | #2 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
I wouldn't worry too much.
First of all, 91 is the MINIMUM octane rating. The owner manual states that you could experience engine knock at high temperature start ups. And yes, you may experience less performance with it. The RECOMMENDED octane rating is 93. As you can tell by your own experiment that one it two octane points make the difference.
Rick
05-29-2018, 10:35 AM | #3 | |
Rep 1,466
05-29-2018, 10:47 AM | #4 | ||
Rep 1,659
It can be hard to find good gas. I have certain brands I like to use. Even they vary from location to location. I use a lot of "Top Tier" fuels and that seems to work. My favorite is VP Racing Fuels 93 octane. I know it's not a Top Tier fuel but my car runs great on it. I don't know if you have it there. If you think you have a problem get a sample and document on video getting it. I'm pretty sure that you can find a lab that could test it.
Rick
05-29-2018, 12:30 PM | #5 | |
Rep 1,466
VP Racing 93 isn't available here, unfortunately. I think it will need a lab to test it... that's what I'm hoping someone on here will know how to do, and others in the bay area that might be interested in joining the fight / gathering data.
Johnsonuspp44.00 |
05-29-2018, 01:31 PM | #7 | |
Rep 1,466
I've also been tracking the data logs over a few tanks now, and whilst I'd be prepared to accept a tank, or even two, of 'bad gas'. Right now, I'm struggling to actually find 'Good gas'!
05-29-2018, 03:04 PM | #9 |
Rep 87
Do you feel anything when you have "knock detected" or is it only noticed by the logs? I don't have BM3 so I'm not aware of these gas quality. I'm always filling Shell V-Power. It seems to be doing ok.
05-29-2018, 04:29 PM | #10 | |
Rep 1,466
It's well known that using 91 Octane gas results in lower power and torque compared to using 93 94. The engine is capable of adapting to 91 without serious damage, but I believe using less than 91 could cause damage over a long period of time. Any damage would probably be slow, so it wouldn't even be apparent yet; our cars are too new.
05-29-2018, 06:31 PM | #11 |
587
Rep 897
Ouch.. that's no bueno.
Yeah I'm also in socal and I don't get any of what you see. The shell VPower+ Nitro station by my area generally has very good fuel quality. If you have bimmerlink and a OBD, you can measure the fuel quality realtime and see what type of power it is pulling. Or also use ISTA+ to measure your fuel quality over time.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
05-29-2018, 06:32 PM | #12 | |
Rep 1,466
05-29-2018, 06:34 PM | #13 |
587
Rep 897
Once you do a vehicle scan, click on the DME module and use "call ecu functions" then there should be some diagnostics method in there to get the fuel quality. If it's not there, then just search for fuel quality and there should be a measures plan to call up the information.
05-29-2018, 06:37 PM | #14 | |
Rep 1,466
05-29-2018, 09:58 PM | #15 | |
Rep 6,638
This makes it seem like tuning in the bay area or CA at all is foolish if you're going to use pump gas, maybe even driving a car that requires premium in this area is foolish? If it runs out they're selling 88 gas as 91 that seems like a news story. Highest prices gas in the country, second highest taxed gas in the country, but this most expensive gas in the country sold as 91 is really 88? As a side note I notice my gas mileage isn't what it should be here in this area... related? Last edited by akkando; 05-29-2018 at 10:53 PM.. |
05-29-2018, 10:57 PM | #16 | |||
Rep 1,466
One thing that concerns me is that the octane rating in the US is AKI, which is an average of the RON (Research Octane Number) and MON (Motor Octane Number). A gasoline with an AKI of 91, could have a high RON, and a lower MON. RON is a test more representative of a forced induction engine under load, so a high RON with a low MON wouldn't be a good fuel, even though it is technically 91 AKI. It's difficult to find the RON and MON values for pump gas, but VP Racing and Sunoco do provide details for all of their racing fuels. Unfortunately there are so many different types of fuels, with Ethanol (oxygenated) and without, so it's difficult to draw any conclusions. Quote:
The irony would be that our poor gas is supposed to be 'better' for the environment, but prevents cars from running more boost, which makes them more efficient, which is therefore bad for the environment. I realise that in our cars, the boost is used simply to get more power, but the trend these days around the world, but particularly in Europe, is to down size engines, and add more boost.
05-29-2018, 10:58 PM | #17 | |
Rep 6,638
05-29-2018, 11:03 PM | #18 | |
Rep 1,466
What is it in Bimmerlink that tells you fuel quality? In what way is fuel quality quantified? Are you just suggesting to look at timing corrections, because we get this from the BM3 logs anyway don't we?
05-29-2018, 11:09 PM | #19 | |
587
Rep 897
In bimmerlink there is a PID to measure the DME reported fuel multiplier. Anything less than 1 would mean less than perfect fuel quality. On shell VPower+ Nitro 91 here in so cal, I generally average about .98 to .99 on the stock tune, with occasional 1.0+ I'm not at my car right now and bimmer link doesn't allow you to view the saved dashboard settings until you are connected. I'll chime back here, along with ISTA screenshots when i work on it tomorrow.
05-29-2018, 11:11 PM | #20 | |
Rep 1,466
I'm writing an email now to VP Racing, in case they can shed some light on the subject. They obviously know their fuel!
05-30-2018, 12:29 PM | #21 | ||
Rep 6,638
06-01-2018, 12:56 AM | #22 |
Rep 141
You’re threatening a lawsuit against the oil companies (who have a team of lawyers, good luck) because someone on the internet said you “might” have 88 octane fuel? Do you even hear yourself? I’d venture out on a limb and guess the car would run fine on 87 so long as you’re not tracking it exclusively.
