Can anyone think of an easy way to measure discs?
06-04-2018, 11:31 AM | #1 |
Rep 1,018
Hi,
odd question, ive got a 2010 LCI E91 325d SE so 3.0 N57 Auto... want to buy new REAR discs and fancy the drilled zimmermans (yh partly for looks tbh) how do i know what size discs i have? shy of taking the wheel off and then the rear disc which isnt an easy job given they are normally stuck on and take alot of hammering to get off.... not something i would do on a disc i was refitting and i don't own a disc puller can anyone tell me what i should have? or a smart way of measuring them? would need a bigger set of callipers then i have.... i don't mind popping the wheel off if i need to but if i don't have to it will save alot of faff and travel on my part as i live on a slope, and don't like working i the street. cheers Andy |
06-04-2018, 01:25 PM | #4 |
Rep 2,003
Drives: F30 335d
Not a major drag to remove and refit brake discs tbh. Bash the backside with a rubber mallet and the disc will come off. Don't really need a disc puller.
06-04-2018, 02:48 PM | #5 |
Rep 55
Put two sticks resting on either side of the disc, through the wheel... measure distance between...
No wheels were removed in the writing of this comment... 😀 |
Chappers 715526.50 |
06-05-2018, 02:53 AM | #7 | |
Rep 1,018
Yeah I do feel rears are bigger then fronts but that can’t be surely?! I notice it when washing the wheel barrel. The last e91 rear brakes I removed took some serious welly, I guess I’m being a bit lazy too tbh! I’ll double check real OEM too Thanks guys |
06-05-2018, 02:57 AM | #8 |
Rep 55
06-05-2018, 05:53 AM | #9 |
Rep 398
Drives: Merc, VW, Porsche, Suzuki
The fronts will be 330mm diameter, 24mm thick
The rears will be 336mm diamater, 22mm thick So you're right in saying the rears are larger. For removal, make sure the handbrake is off. You may also need to release the handbrake shoes a little (inspection hole & the cog you need to turn with a screwdriver). I have never seen a rear BMW disc refuse to come off - but I have seen people spend hours hammering everything in sight as the handbrake shoes are still binding.
Audi A4 Quattro 2.0TDI 177 2012/12
VW Golf GTE Advance 2017/67 Porsche Boxster 986 2.7 2000/X Suzuki GSXR 750 2004/04 |
06-11-2018, 12:15 PM | #10 | |
Rep 1,018
