Dashcam Installer
06-09-2018, 04:18 PM | #1 |
Rep 137
Dashcam Installer
Anyone can recommend a reliable and reputable dashcam installer in the UK?
I would need to hardwire the kit to the car battery/fusebox. I'm in Bromley, but happy to drive up to 4/5 hours for the right installer. |
06-10-2018, 03:10 AM | #2 |
Rep 2,048
simon at "KYCS" is based near Birmingham/oldbury. I can highly recommend his services.
https://www.keepyourcarsafe.co.uk/ |
06-11-2018, 08:31 AM | #4 |
Rep 2,343
Very easy to do yourself.
On mine I got 2x 5m long usb cables. These you can run along the edges of the car by simply pressing them into the caps. A double usb 5v outlet A cigarette lighter socket Add a circuit fuse tap I soldered my wires but you can get the crush (crimp) down connectors now. Just a set of plyers will do. Then press the patch into the fuse board and place the earth side under the screw next to the fuse board. I know not everyone is up for doing it but I thought I'd post the info for anyone who wants to try.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
06-11-2018, 11:18 AM | #5 |
Rep 1,268
+1 As above - do this yourself it's very easy.
I personally fed the wire around to the fusebox behind the glove compartment and tapped into a fuse which turns off with ignition. From memory it was the parking sensor fuse. |
